Results 1 to 14 of 14
Thread: Timer runs, but won't click over to stop or start new cycle. Repairable?
    Dallas, TX
    227
    This is the timer in there now. We just bought this house. The timer seems to get stuck a lot when trying to either turn on when off or vice versa. T just gets hung up and won't roll over past the first or last tab to change status.
    Any ideas to repair or the best one to go with that will match size and voltage..
    in ground Gunite pool gallons TBD,, 1 1/2 HP motor running pool and Polaris 380 via a Jandy valve, DE free size TBD.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    38,251
    Re: Need new timer, what to replace this old one with?
    The Intermatic mechanical timers are pretty bullet proof. You would want either the 101 or the 104 depending on your voltage ... although they do not have the freeze protection if you care about that.
    Dallas, TX
    227
    I do need a freeze protector so a similar one from international might make sense to avoid buying two items.
    http://www.intermatic.com/en/Product..._Controls.aspx
    Never had one of these before, so didn't know if there was a way to fix this one, or if this is a common issue with this type. I've only ever dealt with the normal intermatic timers.
    New house; in ground Gunite pool gallons TBD,, 1 1/2 HP motor running pool and Polaris 380 via a Jandy valve, DE free size TBD.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    You could go with Intermatic's digital, PE153PF, but it's double the cost of an exact replacement of what you have.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Dallas, TX
    227
    From what I am seeing, a replacement just like mine is around $150 on Amazon. The 101 or 104 are closer to $50, but would writing be difficult switching from one to the other and losing the freeze protector?
    Dallas, TX
    227
    Could it be a motor issue?
    Re: Timer runs, but won't click over to stop or start new cycle. Repairable?
    It could be the motor, though the motors generally either work or fail completely. Binding up like your describe is usually either the switch getting sticky or something getting bent/misaligned.
    The simplest thing to do is to replace the whole mechanism with an identical one. It wouldn't hurt to try replacing the motor first, though it might cost less or might cost more.
    Dallas, TX
    227
    OK thanks! its missing some of the tabs as well, so may just be best off getting a new one just like it.
    Dallas, TX
    227
    Quote Originally Posted by JasonLion View Post
    Is there a certain place on these where it tells you the voltage or model #? So I know the correct one to get?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    What about spraying the switch with some electrical contact cleaner? Turn off the breaker first.
    If your pump is 1 1/2 HP or less, then a PF1103MT. For 240 volt pumps over 1 1/2 HP you want PF1102MT.
    Dallas, TX
    227
    Ok great thanks!
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Worst case is you just get a normal timer to replace it and then when the cold weather comes along you just make a mental not to watch the forecast and when they say a possible freeze, turn the pump on and let it run all night. That what I do.
    Paul
    Dallas, TX
    227
    **Update** Ended up getting the same timer as before, and had a local guy who used to own a pool company and helps out neighbors put it in for $50. Works great. Thanks for all the help!
