Thread: Replacement liner inside of Intex 18' metal frame
    Apr 2015
    austin,tx
    1
    So happy I found this site/thread..... my 18x48 has leaks and Intex is tooooooo much to replace with one of their liners.... my question is: expandable or the correct size of a lap over or even a size up (52 wall)? I am assuming that the expandable doesn't have a circular seam and that would make it easier to fit. Thank you for your input.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Replacement liner inside of Intex 18' metal frame
    Is it cheaper to buy a new pool as opposed a new liner?... even an overlap costs a fair amount.
    I would hate to hear the pool failed at the rip/leak.
    -- Guy --
    Casey's Avatar
    SW PA
    10,453
    This has been done before many times. Search for liners in intex pools n the thread should come up.
    Jul 2014
    Andrews, SC
    11
    I saved this link for when I need to replace my liner. The intex liner is nearly the cost of a new pool, so I figured this would be an option.
    http://www.troublefreepool.com/threa...18-metal-frame
    Jun 2012
    MA
    347
    Quote Originally Posted by lovey View Post
    You should try fixing the leaks. Last year I had about 40 leaks when I set up the pool. There were no leaks when I took it down the year before. I found all the leaks, which were all on the bottom near the edges. Set up the pool and fill it with about 1/2" of water. Look for wet spots around the perimeter. You can fold the bottom of the pool over and press down to see where the leaks are. I would mark them with a sharpie
