Results 1 to 8 of 8
Thread: Opening
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    513
    Opening
    Last year was the first season with my current pool.. Today I took my water's temp..it is at 52. All the ice has melted inside. My weather app has about 2 nights in the coming week and a half that will dip into 30's at night. Is it too soon? And yes..I'm super exited to get it going.. This is what it looked under the cover today.. Sneaked my phone through the skimmer. Attachment 35182
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    38,520
    Re: Opening
    Definitely not too soon. You want to open before the water gets above 60. A couple nights in the 30s are nothing to worry about ... just run your pump at night if the temp gets around freezing.
    TSiGirl's Avatar
    Mar 2013
    513
    Re: Opening
    Thank you for the prompt reply Jason! Will work on it tomorrow!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Opening
    +1 with Jblizzle. Now is a good point to start at as you will not have to be looking at a green monster.
    Solar Blanket, Well Water, Borax Added. 76
    Casey's Avatar
    SW PA
    10,457
    Re: Opening
    I opened mine on Monday to crystal clear water. It needs swept but I'll do that on Saturday.
    TSiGirl's Avatar
    Mar 2013
    513
    Re: Opening
    Took the cover off and opened to this..
    Only snag so far is this leak under the skimmer..I think that gasket is toast..
    TSiGirl's Avatar
    Mar 2013
    513
    Re: Opening
    After circulating the water for awhile my numbers are:
    Water temp is 54
    FC- 9
    CC- 0
    PH- 7.0
    TA- 140
    CYA- 40
    38,520
    Re: Opening
    You are golden ... just need to bump the pH a little
