Thread: Vinyl liner or Plaster ?
    divepool's Avatar
    Aug 2008
    St. Charles IL
    Looking for pro/con of both IG liner pool VS plaster? I am looking for help as I can go either way install a liner or plaster the interior.
    Thanks for your help
    22x52 IG 56K gal 3.6' to 11.6' deep, TruTile w/Vinyl Liner IG pool w/ 12" wide safety ledge
    StaRite System 3 Cartridge filter 450sqft S8M450, Pentair IntelliFlo VF pump 3.2KW
    Hydronic in floor heat & StaRite SR400HD, Pro Logic PS16 w/2 40K Turbo cells.
    4 Hayward Colorlogic lights, Dolphin DL3002 Robotic cleaner
    Saint Charles, IL
    Butterfly's Avatar
    South Carolina
    Re: Vinyl liner or Plaster ?
    Hi divepool,
    Here is a thread w/some info that might help: fiberglass-vs-vinyl-vs-concrete-igp-t6065.html?hilit=%20vinyl%20plaster
    Also, you can do a search with +vinyl +plaster and get some more hits.
    HTH and welcome to the forum!
    You're done SLAMing when:
