Results 1 to 15 of 15
Thread: SLAM done?
    Apr 2015
    Knoxville, TN
    64
    SLAM done?
    I've been slamming since we opened a swamp last week. No CC and we pass the OCLT but the pool is still cloudy/milky, not clear. Could this just be old algae needed to be filtered out? Hate to keep slamming if we don't need it. Thanks.
    Sand filter
    Salt Generator
    25000 gallon IG Vinyl
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SLAM done?
    Welcome to the forum if I havent said so.
    No, you need to be clear to be done. More filter time is needed.
    Essential Links:
    Apr 2015
    Knoxville, TN
    64
    Re: SLAM done?
    Thanks for the welcome. My cc is zero and I've held 24 FC for a couple days by adding tiny amounts of bleach. Obvious passing OCLT. Just still cloudy. I can barely see the drains in the deep end.
    Sand filter
    Salt Generator
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: SLAM done?
    Patrick ??
    They are good with CC and they passed the OCLT so it's just a need for a lot of filtering to get the dead stuff filtered out.
    Solar Blanket, Well Water, Borax Added. 68
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SLAM done?
    Just hang in there, maintain residual for SLAM until you are clear. Once clear, you can let the FC drift back down. If you follow this, it won't rebound on you.
    Essential Links:
    Apr 2015
    Knoxville, TN
    64
    Re: SLAM done?
    Thanks! When I backwashed today a lot of crud came out. So we've gotta be moving forward!!!
    Sand filter
    Salt Generator
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: SLAM done?
    I like sand filters and I have one but from others posts they do seem to lag a little behind when doing a slam. It isn't uncommon for you to get below the .5 and your chlorine is holding but it's still cloudy
    Just need to hang in there and you'll be sparkling blue shortly !!
    30,403
    Re: SLAM done?
    The slam is NOT complete until your water is crystal clear. We know that can be a bit of overkill sometimes but we have often seen many folks let their FC down far too early and end right back up with a green swamp. It is not worth the chlorine savings.
    So, The official TFPC stance is....
    1. Your pool water is sparkling
    2. Your CC's are .5ppm or less
    3. You can hold your FC overnight without losing more than 1ppm.
    Often, it is the SIZE of the filter rather than the type that makes the process slow down.....not saying that in your case but just fyi.
    Apr 2015
    Knoxville, TN
    64
    Re: SLAM done?
    Thanks again. I guess I'm ready to get this thing done. Haha. I don't want to go back, so we'll keep it at slam level until it's clear.
    Sand filter
    Salt Generator
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SLAM done?
    Yea, I understand it's a test of your patience.
    Essential Links:
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Re: SLAM done?
    I have a sand filter on my pool and when I had to SLAM, a little bit of DE added to the filter through the skimmer helped with removing a lot of the cloudiness.
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: SLAM done?
    I've done that too, just need to be careful about how much you use and make sure you don't get garden DE but something that's for pool use.
    http://www.troublefreepool.com/conte...-a-sand-filter
    Apr 2015
    Knoxville, TN
    64
    Re: SLAM done?
    I'm afraid of DE right now. Haha. Baby steps. But you guys were right. I did another OCLT today just to see, we failed. Lost 4 ppm. Ugh...something is still there. Die algae, DIE!!!
    Sand filter
    Salt Generator
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SLAM done?
    Quote Originally Posted by Rere View Post
    This is why we have the criteria. Don't worry, It will clear, I promise. Keep at it...
    Essential Links:
    Jul 2015
    Sacramento, CA
    15
    Re: SLAM done?
    If all of the above are true, would it still be possible to have the slight appearance of green algae anywhere in the pool? (or any type of algae).
    In years past I have had spots of black algae in my pool. I have some darker looking algae on the step by my waterfall. It could just be dirty/stained, I'm not quite sure yet as I'm not done with my SLAM, but this is why I'm asking. The 3 criteria don't call this out specifically so I don't want to assume (although I guess if the point is to kill everything, there really shouldn't be?)
    Odd shaped "sport" style pool, in-ground, plaster. ~13-15k (hard to get accurate estimate due to shape). Cartridge filters (hayward). SWG.
    Taylor K-1005 Test Kit
