Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Bio Active Cyanuric Acid reducer review
    Apr 2015
    Southern Cali
    30
    Started maintaining my own pool. Previously had a pool guy and as you can see, doesnt look like he was doing much of maintaining based on my test numbers. CYA is currently at 140. we have a drought danger in California, so draining and refilling the pool is frowned upon. Bought this new product from Bio Active to reduce CYA levels. One pack treats up to 25,000 gallons. Its safe to drop in the entire pack into the skimmer. I've seen price ranges from 41.99 - 59.99 for this stuff. Test results have shown 150ppm CYA levels to drop to 70ppm within a week. Product indicates it will not harm other parameters of the pool chemistry. I'll post up the results in a week.
    4/8/2015
    17,000 gal
    FAC 0.5
    TAC 0.5
    CH 540
    CYA 140
    TA 80
    PH 7.3
    PHO 500
    16,000 gallon, IG, Plaster, pool and spa.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bio Active Cyanuric Acid reducer review
    Looking forward to it.
    Solar Blanket, Well Water, Borax Added. 68
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Thank you for posting. We're all quite curious to hear how this product performs as it is new to market. I hope it works well for you!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,100
    Hello, and welcome to TFP!
    If at all possible, can you post your daily test results here for us to review? TFP is VERY interested in this product and it's workings.
    38,463
    Wait, how did you get those first set of test results? The PHOS makes me think they were from a pool store and they are notoriously bad at testing CYA. So, to me that would invalidate your experiment since the CYA testing would not be accurate or repeatable.
    Apr 2015
    Southern Cali
    30
    It was a pool store testing, however, I'm inclined to believe they are accurate only because I did an initial water test about one week at a different pool store and the numbers were very similar from both independent pool stores.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Please add your pool and equipment information to your signature as outlined here -> http://www.troublefreepool.com/conte...etting-started
    38,463
    Quote Originally Posted by mendez4047 View Post
    Well, what happens if you have a different person test it next time? And the lighting is different?
    IMO, these results are not going to be controlled enough to get a good feel for the actual effectiveness of the product.
    Apr 2015
    Southern Cali
    30
    That is very true. Then let's just say my results will be a "ball park" numeric figure.
    38,463
    Please realize that the cornerstone of the methods we teach is testing the water yourself with a high quality FAS-DPD test kit. The TFPC method is really just about understanding your pool’s chemistry and through accurate testing, adding only what the pool needs.
    Pool stores have repeatedly been proven to be inaccurate and not repeatable more often than not.
    Apr 2015
    Southern Cali
    30
    Just an update. I purchased a Taylor test Kit. It has been 5 days since I used the Bio Active Acid Reducer. So far nothing has changed. My tests still show CYA levels over 100ppm. I will go to the pool store to get my water tested to see what they come up with and I will compare their numbers to my numbers.
    38,463
    Use the diluted method to test the high CYA as described in the Extended Test Instructions. Forget about pool store testing.
    Apr 2015
    Southern Cali
    30
    Diluted method resulted in a CYA level of 200. I'll update again in 5 days as the manufacturer states it will work for 10 days.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    watching
    I would suggest doing a daily CC test. One of the intermediary products described in the literature is ammonia. Therefore, if the product is working, I would think that there would be some increase in CC levels.
    Support the site
    Apr 2015
    Southern Cali
    30
    Today is day 8 of using Bio-Active cyanuric acid reducer. My personal readings show 200ppm and the pool store shows 140ppm. Absolutely zero decrease in CYA levels since I started.
    I'm going to get ready to drain my pool. Doesn't look like this stuff is going to do magic in 2 more days.
    mendez4047, how are you doing the CYA test?
    We really only believe in the black dot based CYA test, and for high CYA levels it needs to be done with enough dilution to make sure it isn't maxing out, as it will report anything over 100 as 100.
    Apr 2015
    Southern Cali
    30
    I use the diluted method 50% pool water, 50% tap water, then multiply my results by 2. I'm at 100 ppm when the black dot disappears. 100 x 2 = 200 ppm
    Apr 2015
    Southern Cali
    30
    I've also done the diluted method at 25% pool water with 75% tap water, then multiply it by 4. I get the same results.
  20. Back To Top    #20
    That is the important one. Using 1:1 and getting 100*2 means it could be way higher. But using 1:3 and getting 50*4 confirms that it really is 200.
