Thread: Help Sizing Stenner Pump
    Mar 2015
    Sugar Land , TX
    424
    Ok I was going to go with LQ but seems to have to many issues. So Stenner sounds like the solution. I have 8500 gallon pool and use about 48 oz. bleach per day. My math says if I get 45mp2 @25psi pump that pumps 0.89 oz/min that I should only need to run for 54 min/day. Does that sound correct? I should be able to hook up to my ET8 on aux and schedule Stenner pump to come on over night with pump for 54 min.
    Sep 2014
    North DFW
    161
    Re: Help Sizing Stenner Pump
    That seems to be the size alot of people get, including myself. I got the 45MPHP10 which is essentially the same thing, but with an additional check valve. There is plenty of head room up or down with that pump.
    39' x 18' IG 3.5X4.5X9 34k gallon w/ raised spa, 3 stone scupers
    Jandy 60 SqFt DE, Jandy PDA PS6, Jandy JXi400 heater, Jandy 2.0 EPump w/SVRS
    A&A Manufacturing ICS w/G4 venturi heads
    2 incandescent lights in pool, 1 in spa.
    22,549
    Looks like you don't need much help at all. That looks like it'll be a good size pump.
    I like the HP model simply because of the check valve in the injection fitting. That way if you split a pump tube or the injection tubing comes loose you're not spraying a stream of water out of the injection fitting when the filter pump is running.
