Thread: Above Ground Pool Build
    May 2013
    Louisiana
    12
    IN about two weeks in going to start with an adventurous build. I have had an Intex pool for 3 summers now so I think I have the hang of the BBB method. But today I am looking for any prebuild advice to better prepare for this project. I am planning to put an 18x33x54 Melenia above ground pool 24 inches into the ground with an expandable liner. I have very little experience with dirt work but I'm gonna give it a try any way. All that can happen is an over sized KOI pond and an above ground pool above the ground.(plenty of yard space) I would like to install a second return jet. If I have read everything right this would be the perfect time to do it. I promise to post plenty of pictures as I have enjoyed watching many pools come to life. So please any advice hint tips or tricks please fill me in.
    24' 52" intex-----gone
    18x33x54 ABG 7 ft deep end buried 2 ft in the back breaking hard red clay
    Hayward 20 in sand filter 1.5 hp power flo pump
    Casey's Avatar
    SW PA
    10,450
    Re: Above Ground Pool Build
    Check for all lines in the ground. Use an excavator n make sure your level all the way around!
    Good luck!
