Results 1 to 7 of 7
Thread: New Pool owner - above ground. Help please!
    Apr 2015
    Lakeville
    2
    Hello!
    First time pool owner here. I recently purchased a home with a 24' above ground pool - the pool is roughly 14 years old, not sure on the age of the liner. The previous owners did not cover the pool during the winter (we are in Minnesota).
    Over the winter I noticed that the top of the pool was shifting (see attached picture). The top lifted up off of the walls in areas around the pool about 2-3''. In the spring now everything is melted the top has shifted back down but the liner is bulging and sliding off in a few areas. I pulled the liner back up and secured it with some clips temporarily to prevent it from continually sliding off. Any recommendations for how to go about fixing this?
    (Sorry, the picture is sideways. Not sure how to rotate it! You can see that it lifted up off of my deck.)
    Casey's Avatar
    SW PA
    10,421
    Re: New Pool owner - above ground. Help please!
    It looks like the pool heaved a bit. It can be fixed by taking the top rails off and pulling the liner back over the wall and putting the rails back on. It's fairly simple and can be done with a buddy.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,383
    The warmer (I hope that is not ice still in your pool-burrrr) the water and weather is the easier it will be to work on the liner. For right now secure it as best you can to keep the water in if that is ice. If it is not ice do as Casey says.
    Kim
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Matt
    Are you in Lakeville MN ??
    Please add your pools info to your signature as outlined here - > http://www.troublefreepool.com/conte...etting-started
    If you PM me an email address I can send you that photo of the pool shifted off the deck rotated.
    Solar Blanket, Well Water, Borax Added. 68
    Apr 2015
    Lakeville
    2
    Thanks for the replies! Yep - Lakeville, MN. I'll work on the signature, still trying to figure out exactly what the details on my pool are
    In regards to the liner, is this an issue that I should expect every winter when it freezes? Currently everything is thawed out, so I can take the top rails off and work on pulling the liner back over. Also I did notice a few small tears in the liner above the water near the top rails; maybe 1 or 2 inches. I'm hoping this can be patched?
    Jun 2012
    Blaine, MN
    106
    Welcome Matt. Good to see someone from MN. We're up in Shoreview and working with some problems on our pool. Our ice is gone. Is yours?
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    30,400
    bunch of holes and tears, it may be time to think of a replacement.
    You'll probably find out when you place the liner back over the wall. If it has become brittle with age, it will probably tear on you.
    If the tears, etc. are small, you can purchase a vinyl repair kit very readily.
