Thread: Using home gas boiler to heat pool via heat exchange
    Hi,
    I am looking to add a heating system to my pool. At first thought there were two choices, mainly being gas boiler and a heat pump. However, a plumber told us we can heat the pool from the house gas boiler by using a heat exchanger.
    Can anyone supply their experience with such a method or if not give some advice if you have looked into as well.
    Thegirlys
    24' by 52" ROUND AGP, INTEX SWG, SAND Filter
    30,402
    Re: Using home gas boiler to heat pool via heat exchange
    Your plumber forgot to tell you to bring your wallet. A typical home heating boiler may be 50-70,000btu...a typical pool heater is anywhere from 125,000-400,000btu's. Home heaters simply don't have enough "oomph" and will drain your IRA and Investments trying to heat a pool!
    You don't say where you live nor the size of your pool or your house but, generally speaking, you will not have nearly the capacity you need to heat a pool with a house heater.
    Guest
    Depends on the boiler capacity.
    Some of the new "whole house" systems including heating and hot water are higher capacities such as 250K Btu.
    It is cheaper than a new heater just for the pool, but it also adds wear and tear on the current boiler.
