Results 1 to 10 of 10
Thread: Pool Cleaner
    Mar 2007
    Houston/Richmond
    8
    Pool Cleaner
    Hi
    Iam looking at getting a pool cleaner for my pool but what cleaner to get.
    Is the Polaris 380 a good one?
    What other clean are out where?
    This was are pool cleaner but it old.
    Lincoln Mark VIII
    32,000 Gallons Pool with one pump
    Mar 2007
    Houston/Richmond
    8
    If I get a pool cleaner that required a booster pump and I dont have a booster pump will the cleaner still work?
    On my pool you can turn all the jets off and turn the pool cleaner jet on. Does that work like a booster pump?
    Lincoln Mark VIII
    JoshU's Avatar
    New Orleans, LA
    543
    If you have a booster pump pre-installed the Polaris 280 is the best choice. Compared to the 380 the 280 is a gear driven unit whereas the 380 uses belts (prone to frequent replacement).
    If you get a pool cleaner that requires a booster pump (Polaris 180, 280, 380, 480, Baracuda Mars, etc.) you must actually have a dedicated pressure line with a booster pump installed. The Polaris 360 is a modified version of the 380 which does not require a booster pump.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Guest
    Quote Originally Posted by Stone17
    IF (and it is a big IF) the cleaner line is supplying enough water wne all the returns are off then a booster pump requiring cleaner might work but there is no guarantee. My pool is plumbed non standard and I run a MarsHP without a booster pump but it is running off a dedecated 1 hp Pentair Pinnicle that is valved to either power my water features or the cleaner line. It actually has enough flow to run the cleaner without any problems and the water features at the same time. If it doesn't work and since you seem to have a dedicated pressure line it's not that big a deal to replumb a booster pump into the system. Bosster pump cleaners are going to perform better than boosterless ones but units like the Polaris 360 or the Pentair Legend II (both boosterless) do a good job once they are set up..
    Panama City, Florida
    10
    also searching for an automatic pool cleaner
    Hello:
    I am also searching for an automatic pool cleaner. My pool is a 30ft Allegro above ground (22,000 gallons). We had a Polaris Turbo Turtle (aka Polaris 65) but now it only turn circles now and does not clean the whole pole. Replaced the randomizer but it did not fix the problem. Turtle is old and worn out. It did a good job when working though.
    I am looking at replacing it with another Polaris 65 or Hayward Aqua Bug or a Barracuda Ranger. Money is tight and I am looking to save some money. But need to clean the bottom of the pool. Any fans of these auto cleaners?
    Sincerely,
    Ikymojoe
    30' Above Ground Allegro (22,000 gal), 1.5hp WaterWay HiFlo Pump, Sta-Rite Catridge Filter, Polaris 65 auto cleaner
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I know there are a lot of folks out there with Aqua Bugs. I have a Hayward/Sta-Rite Lil Shark that works fine. My next cleaner is a robotic - PoolRover Jr or AquaBot, etc. The prices get better all the time.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    JoshU's Avatar
    New Orleans, LA
    543
    Re: also searching for an automatic pool cleaner
    Quote Originally Posted by ikymojoe
    Hello:
    Sincerely,
    Ikymojoe
    It sounds like the Polaris hose may have "memory". A common issue is when the Polaris hose has is stored people tend to curl the hose causing the hose keep this shape while in the pool. To fix this stretch the hose straight out in the sun for a day or two. Hopefully this can fix the problem for you.
    If not the Aqua Bug and Baracuda Ranger are suction cleaners meaning they hook into your skimmer. These tend to be better for small debris. Whereas the Polaris 65 is a pressure cleaner and tends to work better with large debris.
    Jun 2007
    Marshvegas, MA
    3
    I've been using the Aquabot Turbo for four years now. Works great, never any problems, has come down in price lately. Would highly recommend.
    16x32, 22000gal vinyl, Hayward 1hp, Hayward ec65
    Fort Worth, Texas
    32
    PoolRover Jr here and it works great..
    28K IG, stonescapes pebble, raised spa, hayward heater, 2HP Super II pump, Hayward 60ft DE filter, built around 1980, remodeled 2007.
    10
    Thanks for the replies
    Well, I purchase a Polaris 65 and it has been working great. Found the outlet hose tube now has a different connector (male threaded) than my old Polaris Turbo Turtle. So, I switched out the new one with the old one. When the pool is shut down, I will switch out the connectors. Found a memory problem as described previously by JoshU, so I stretched it out in the sun for a few hours and it has been working just fine.
