Thread: Activated Charcoal
    Mar 2015
    Georgia
    157
    Activated Charcoal
    Wouldn't activated charcoal remove impurities from the water if one had a big bag of it in the skimmer?
    Would it remove cya, chlorine, calcium and other such things as the water passed over it?
    16k AG Vinyl Sand Filter
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Re: Activated Charcoal
    Unfortunately, it does the opposite of what one needs in a pool....it removes chlorine and DOESN'T remove coliform...recipe for disaster
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    It will remove chlorine, which is not desirable. Some have used charcoal on the water supply side.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    It would also saturate very quickly and need to be reactivated before it could be used again. So it is totally impractical, even if it did something useful.
    Mar 2015
    Georgia
    157
    Yea I was wondering why I havent seen it mentioned. Thanks guys.
