Results 1 to 18 of 18
Thread: Outdoor Kitchen Question
    Kinglangon63's Avatar
    May 2014
    Ontario,Canada
    41
    Planning on building my outdoor kitchen very soon. Grill is a DCS 48" grill, Marvel 24" outdoor fridge with DCS under the grill storage cabinet with DCS dual sideburner. And another storage compartment under the side burner. Here are my questions.
    1. Is Aluminum 1.5" x 1.5" tubing strong enough
    2. I will use thin veneer stone , do you install the stone first or the stainless steel cabinets storage drawers first?
    3.Is 1/4" hardi backer thick enough for the front and sides?
    4. Do you need to use hardi backer on the top or a countertop direct ok?
    18' x 30' Completely Automated Fox Pool
    2 Pentair Intelliflo VS pumps
    Pentair 250 HD Heater
    Pentair Cartridge Filter & IC 20 Chlorinator
    Intellitouch i10 Automation & Sheer Descent x 3
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Outdoor Kitchen Question
    Welcome to TFP!
    I'll tackle a couple of these...
    3. Is 1/4" hardi backer thick enough for the front and sides? Yes, that's what I used when I built mine and still going strong on its 10th season, including a move to a new house.
    4. Do you need to use hardi backer on the top or a countertop direct ok? If you are going to put tile on the countertop (like I did), I would go with the thicker hardi backer which I believe is 3/8". The other factor with mine is that, although it looks built-in, it is movable (on large hidden casters). Occasionally, I do move it and I wanted extra protection from any twisting/torquing forces while moving.
    Oct 2013
    Northern California
    23
    I will tackle #1 & #2....
    1. Is Aluminum 1.5" x 1.5" tubing strong enough. I would suspect the aluminum tube is plenty strong enough, but it's really a function of what center spacings they will be on and how much load you want to place on them. That shape is fairly rigid compared to steel studs, so I can't see why it wouldn't work. Just so you understand my opinion on your choice of framing material, I'm a civil engineer during the day.
    2. I will use thin veneer stone , do you install the stone first or the stainless steel cabinets storage drawers first? We installed the stainless steel cabinets first, then came the thin veneer.
    Best of luck on the build and post pictures. I think we all like seeing what people come up with.
    Mark
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Quote Originally Posted by mweisz View Post
    Same with us. The frame of the doors and drawers gives you the line to which your veneers need to be cut to and then set against.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    Jan 2013
    Friendswood, TX
    320
    I'll answer them too... Just for fun.
    Should be dependent on your countertop material. I used 20ga galvanized channel. The worry I would have about square tubing is joint connections. How are you making the joints? With channel you slide on in the other.
    Install the 1/4" hardi, then doors and drawers, then install the stone. I didn't put the rock right up against the door frames as I could never get it to be perfect so I left some grout area. Then I put blue tape on the door frames and grouted the area between the stone and door. Pull the tape and you have a clean edge.
    Yes.
    I did. However I did a poured in place concrete counter. The only way you could not have something there is if you did a slab counter. If you are doing granite or the like slab, then no you don't.
    If you click my build in my signature I have very detailed steps, diagrams, and you can see how I solved issues that I didn't know of till they came up.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    May 2014
    Ontario,Canada
    41
    I was planning on welding the frames. Also I saw your photos nice. Another question. Did you have to compensate the height for the grill with the addition of your countertop and did you plAce the grill on the frame or on the cement counter
    Quote Originally Posted by Jabooh1 View Post
    Yes.
    Jan 2013
    Friendswood, TX
    320
    My counter is a little taller than normal, about 38". 36" stud, 1/2" footing, 1.5" counter. I didn't mind though as it was easier than cutting every stud.
    The grill is sitting on the concrete counter. I did a pour in place counter and each cutout has a horizontal stud right at the edge near the appliance. The shelf under the Primo ceramic grill (175 lb or so) has extra horizontal and vertical reinforcement.
    ~Paul
    May 2014
    Ontario,Canada
    41
    I have my aluminum frame built up, did it on the weekend using 1.5" aluminum tubing 1/8" thick. It's 10' long and 1 piece. I will cover all sides using 1/2" du rock cement board. The back is going up against a brick wall and this will be covered, it's under my loggia, is the back ok with cement board?
    May 2014
    Ontario,Canada
    41
    Aluminum frame
    Jan 2013
    Friendswood, TX
    320
    Cement board can and will absorb water. You need some sort of waterproof coating.
    ~Paul
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    That frame looks indestructible...I like it!
    I'm not sure you need to waterproof the back, if it is underneath a roof as you say. If it is not going to get wet, and isn't visible, I'd be awfully tempted to leave it bare too.
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    I'd be inclined if you are painting the rest before it's final location to just add the waterproofing to the back. Can't hurt anything.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    May 2014
    Ontario,Canada
    41
    I gave it a coat of Flexbond on the backside, step 2 is complete
    Jan 2013
    Friendswood, TX
    320
    Looks good!
    ~Paul
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Is that all welded together...? Nice...
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    May 2014
    Ontario,Canada
    41
    Yes it's welded together. I then used stainless steel screws for the Durock cement board. Stone should be going on in a couple of days. I have installed the appliances except for the fridge.
    Jul 2014
    461
    Looking good!
    May 2013
    Ontario, Canada
    63
    These are the types of threads that make me want to make one of these myself. Looking great!
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
