Results 1 to 12 of 12
Thread: FC at 90 PPM
    Apr 2015
    Orlando, FL
    2
    FC at 90 PPM
    I recently drained and refilled my somewhat-green pool at the recommendation of a pool store guy due to an abnormally high CYA level (100-200PPM?).
    After refilling on Sunday, I was still waiting for my TF-100 test kit to arrive, so I put in an entire jug of liquid chlorine (from the pool store). I think it's 2.5 gal in size. Not sure about the concentration.
    Today (Wednesday), I got the test kit, and here are the results (I did my best to follow the instructions exactly, but this was my first time doing this):
    FC: 90
    CC: 0
    TC: 90
    CA: 325
    TA: 90
    CYA: 35
    pH: 7.6
    The pool is currently blue and mostly clear - just a tad milky in the deep end. From looking at the chart here: http://www.troublefreepool.com/conte...art-slam-shock I can tell that my FC is much better closer to 4ppm, and even the shock level is much lower than what I measured.
    I am assuming that this high FC level will go down by itself in a couple days, and I plan on measuring it every day to plot its progress, but I am wondering if there is anything else I should be doing. I am afraid that my impatience is going to prevent the pool from being safe to swim in this weekend.
    Edit: As noted in my later post, I did the FAS-DPD test incorrectly due to not swirling the mixture after each drop. The actual FC is closer to 12 ppm.
    Pool Stats: 9500 gallon in-ground plaster/pebble pool | Hayward sand filter | Covered with a screen | Sunny Orlando, FL
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,418
    Re: FC at 90 PPM
    Are you sure the FC is 90? If your CYA is 35 an FC of 90 is way to high to swim safely.
    You would have had to add 7 gallons of 12% liquid chlorine to get from 0 to 90.
    Love TFP? Become a
    TFP Supporter!
    38,475
    Re: FC at 90 PPM
    Welcome to TFP!!!
    Blindly adding that much chlorine is a REALLY BAD IDEA.
    Assuming the concentration was 12.5%, using PoolMath (you need to learn to use this), 2.5 gallons would have only added 33ppm of FC to your sized pool. So something is wrong with your test. Did you use 10ml or 25ml of water? How many drops did you count?
    There are Youtube videos posted on the tftestkit.net website.
    The FC will drop as the sun breaks down the chlorine. Luckily it does not look like the FC should have gotten high enough to damage anything.
    You need to properly follow the ShockLevelAndMAINTAIN Process before the pool is going to be safe.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: FC at 90 PPM
    Are you sure you did the test correctly? 2.5 g of chlorine should not raise it that far. If you are using the FAS DPD test, remember each drop is 0.2 ppm for the 25 ml level and 0.5 ppm for the 10 ml level.
    Mark
    Apr 2015
    Orlando, FL
    2
    Re: FC at 90 PPM
    I just watched the video, and it looks like I missed the "constant swirling" in the instructions. Got 24 drops, or 12 ppm this time. I should read more carefully!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Re: FC at 90 PPM
    Good Deal! You had us worried there for a minute!
    Quote Originally Posted by GGMark View Post
    Divin Dave,
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Re: FC at 90 PPM
    GGMark,
    Get a Taylor Speedstir and swirling will be a thing of the past. Trust me when I say you will love it. One of the best investments I have made for my pool. Welcome to the forum.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jan 2014
    Buckeye AZ
    807
    Re: FC at 90 PPM
    how did you get a CYA of 35 just after refilling?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Mar 2010
    Spring, TX
    1,082
    Re: FC at 90 PPM
    Quote Originally Posted by ComputerGuyInNOLA View Post
    GGMark,
    I agree 100% with this.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Casey's Avatar
    SW PA
    10,457
    Re: FC at 90 PPM
    Gotta swirl it! lol
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Re: FC at 90 PPM
    GGMark,
    Speedstir FTW! Get one,it's really not that expensive. Just think of all the pool store money you are going to save.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Re: FC at 90 PPM
    Quote Originally Posted by BuckeyeChris View Post
    i would second this question. When did you refill, how much of what did you add to get the CYA in the water? When did you add it?
    It can take up to,a week for CYA to register on the test.
    Support the site
