Results 1 to 8 of 8
Thread: quick CC question
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    quick CC question
    My CC went up from 0 on Sunday to 0.2 tonight. My FC dropped from 8 to 6.4 overnight, but we had a high of 86 and people have been swimming regularly. Also the pool is in direct sun until around 6. I'm not worried, just wondering if that sounds normal or is that the canary in the mine. I guess my real question is, when you see an increase can you just increase the FC double the CC to combat it early rather than wait for a SLAM later.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    38,475
    Re: quick CC question
    If the CC is not more than 1 drop ... it is nothing to worry about.
    Use 10ml of water so each drop is 0.5ppm.
    May 2014
    Clarksburg, WV
    331
    Just curious how you came up with .2 for your CC?
    Its either 0, 0.5, 1, 1.5 and so on with the recommended test kits.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    He was using a larger sample. It has a different multiplier.
    Essential Links:
    38,475
    To be a little more verbose ....
    If you use 25ml of water (as the K-2006 suggests), each drop is 0.2ppm
    If you use 10ml of water (as the TF-100 suggests), each drop is 0.5ppm ... this is plenty accurate and saves a lot of reagent.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Thanks, I will start using the .5. To test my theory I added slightly more bleach to not only bring the FC to the recommended amount, but add a bit more essentially I figured double the CC and today I'm at 0 CC.
    38,475
    Doubling the CC was just a coincidence ... the CC may have been removed by the sun.
    May 2014
    Clarksburg, WV
    331
    Hmmm. Learn something new every day.
    TF-100 Test Kit
    How to SLAM
