Thread: Above Ground Deck Width Opinions
    Cypress, Tx.
    154
    I have an 18ft diameter above ground pool and have extended my 16ft wide deck out to the pool (coped around a section of the pool). I want to build a deck addition that goes around the pool that with at top of deck elevation approx 12" above grade, well below a level to use it to enter the pool. This deck will be used to essentially clean up the appearance around the undecked area and provide a nice walkway for maintenance. What would be the minimum width of this deck walkway. I dont need a big walkway around.
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    Feb 2015
    Bardstown KY
    139
    Re: Above Ground Deck Width Opinions
    2 feet is the narrowest walkaround that I've seen, though I would think 3 might be preferable.
