Thread: Pool Antifreeze - Cartridge Filter
    Mar 2013
    CT
    349
    I see there is a lot of posts about back washing the filter once it's first started to remove any antifreeze that was put in the pipes when the pool was closed.
    What does everyone do when you have a cartridge filter? I probably used about three gallons when I closed my pool...
    Can I just start the pump and let it into the water? I used pool specific antifreeze.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Re: Pool Antifreeze - Cartridge Filter
    As long as you used pool or RV anti-freeze it doesn't really matter. A few gallons in the pool won't be detectable and will not cause any problems.
