Thread: Ladders and Handrails question
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    154
    I don't remember where, but I read it is good practice to lubricate your handrail and ladder posts in the cement before reinstalling them. Does anyone do this, and if so what do you use? Thanks!
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Dec 2009
    Central Massachusetts
    2,690
    Re: Ladders and Handrails question
    I use marine grease
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Feb 2012
    Maryland
    400
    Quote Originally Posted by bk406 View Post
    I use marine grease
    ditto this. First year was a pain getting them out. After that put marine grease in them and in the fall ladder slides right out!
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Jul 2014
    Hickory, NC
    154
    Thank you!
    Sent using Tapatalk
    ~ TF-100 test kit
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Where might one find marine grease? Do I need to find a boat store in my area or can I pick it up at one of the big box stores?
    As I posted this I realized I can always just check Amazon being that they pretty much have everything.
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
