Thread: Pentair Easy Touch and IC 40 SWG questions
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have a couple questions about Pentair Easy Touch being used with IC40.
    First, can anyone tell me how to ensure the Chlorine output of the IC40 can be set to 0, or be turned off via the easy touch.
    Next - I think the answer is no, but want to cofirm it. - With the IC 40 connected to the Easy Touch, can the output % be adjusted at the cell
    by pushing the buttons?
    Thanks
    Divin Dave,
    Re: Pentair Easy Touch and IC 40 SWG questions
    When connected to an EasyTouch the buttons on the IC40 stop working. All adjustments to the SWG need to be through the EasyTouch.
    You can "turn off" the IC40 on the EasyTouch Settings menu by either setting Enable to No, or by setting both the pool and spa percentages to zero.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Thanks Jason.
    Divin Dave,
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by JasonLion View Post
    I just turn off the breaker that controls the IC40 if I want no production for a couple days.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Mar 2011
    441
    Or you can go in to the easy touch and turn the % to 0
    20X40 30,000 gallon gunite pool
