Thread: Configuring gas heater and solar
    I currently have solar panels installed, but they just don't get enough sun to really heat my pool to what I would like. We are getting a gas heater this year. Is it practical to have both hooked up or just use the gas heater? If you use both, how do you set it up? I would like to maximize the use of the solar when the weather is nicer, but still use the heater to boost when needed.
    18x33 above ground pool, vinyl liner, starbright DE filter, 1.5 HP Dynamo pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Configuring gas heater and solar
    Definitely good to have both. Water needs to go through solar first and heater second.
    There is also pool automation that can control all of it, like the Pentair Suntouch. I am most familiar with Pentair because that is what I have but other companies make similar products, Hayward, Jandy, etc.
    To take full advantage of a setup like that one you need some kind of solar controller that understands how to control the combination system. The simplest solar controllers won't work, but most of the automation systems know how to handle a setup like that.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    What you need to do is have the heater installed after the solar. This way the solar panels will collect some heat and then the heater will pick up the difference. That's really the only way to do this and it's done like this alot.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
