Results 1 to 17 of 17
Thread: Problems with my soalr heating controls
    San Juan Cosala, Jalisco
    53
    I use solar panels to heat my pool. I use two sensors, A Hayward Goldline valve actuator GVA-24, and a Hayward Goldline GL-235 Solar pool controller. Ever since lightening struck near my house and destroyed my computer and satellite TV receiver my pool heating system hasn't been working properly. If the pool temperature is 27C the valve will open once it is moved up to 24 rather than at 27.
    The local pool guy says I should replace my whole system but his office person says he is just trying to make sales. Technicians came and checked my system and thought it might be the sensors ($1,200US each!). It has been 4 weeks now and I'm not getting anywhere. Does anyone have nay thought s about this?
    38,475
    Re: Problems with my soalr heating controls
    What sensors? The temperature sensors? Those are less than $20 I think.
    That controller costs <$300 and an actuator is <$100.
    53
    Re: Problems with my solar heating controls
    It needs two temperature sensors. One to measure the ambient air temperature at the solar panels. The other measures the pool temperature. I was quoted $1,200US today.
    38,475
    You sure it was not $12?
    Do a search for "Hayward Temperature sensor" They are $25 each all over the place. Just need to be sure to get a 10k thermistor.
    Altough honestly, I would not think lightning would affect the sensors ... more likely a problem in the electronics. Still $1200 is triple what replacing the whole setup would cost.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Something is wrong on that price. You can buy the Hayward GL-235 on amazon.com for $199. That includes the controller only and not the temp sensors and the valve actuator.
    38,475
    Holy cow, that is even cheaper than I thought
    53
    Quote Originally Posted by pooldv View Post
    Something is wrong on that price. You can buy the Hayward GL-235 on amazon.com for $199. That includes the controller, both temp sensors and the valve actuator.
    That is an eye opener.
    DFW, TX
    24,509
    I know, i wanted to check to be sure and I was surprised. Everyone with solar panels should buy one of those.
    Orlando, FL
    690
    I read the questions. Says it is ONLY the controller and the picture is misleading.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    DFW, TX
    24,509
    Quote Originally Posted by f3justusc View Post
    Yes, you are correct. My bad. That is very misleading. 200 bucks for the controller only. But, as jblizzle said, the controller is by far the most likely thing to be damaged by a lightning strike. The temp sensors are under $30 each.
    Orlando, FL
    690
    I wish the sellers would provide appropriate non-misleading pics. The good part is, I now know about this controller and I did not previously. Thanks.
    53
    After having two different sets of technicians several times out it was decided that my two sensors had been damaged by lightening. They were replaced at a much better price-about $200US each instead of $1,200US each. They do operate the valve actuator when needed but the temperature isn't exact like it used to be. Before if it was set for 29C it would turn the water off at 29. Now it doesn't turn the water off until it gets to 31-too warm. Does the solar controller sensor and the sensor for the pool temperature need to be calibrated to match?
    DFW, TX
    24,509
    You should be able to set the temp that solar turns off to any temp you want.
    53
    Can't. The temperature I set isn't the same temperature that it turns off at. If I set it at 29 it turns off at 31. I wondering if there is calibrating that can be done.
    Whatever the actual temperatures vs displayed temperatures, if you want the water cooler, just turn the goal temperature down lower than it currently is. The numbers may not match reality, but it will get cooler, which is what you want.
    53
    Quote Originally Posted by JasonLion View Post
    Of course. But previously the temperature on my solar controller and the digital water temperature reading on my Aqua Rite chlorine generating panel (right beside each other) were in total sync so it made life easier. I was hoping that you could recalibrate the temperature on the Solar pool Controller to get the two in sync.
    DFW, TX
    24,509
    On my Solartouch it is possible to recalibrate the temp sensor in the advanced menu. Not sure if the gl235 has that capability or not.
