Thread: Adding acid and pump
    Nov 2014
    Palm Desert, CA
    99
    How long should I let the pump run after adding muratic acid? I've been adding acid at least one hour before the pump shuts off if not more but thought I'd make sure one hour is long enough. Thanks!
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    38,251
    Re: Adding acid and pump
    One hour is plenty, likely 30 minutes is actually enough as well.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    +1, 30 minutes will get it mixed.
    Solar Blanket, Well Water, Borax Added. 68
