Results 1 to 7 of 7
Thread: Heater Question??
    Jul 2013
    Chicago IL
    83
    Heater Question??
    Have a natural gas Rheem heater all picked out .. Is it ok to run the return water through the heater when the heater is off??.. Or should the water be bypassed with pvc.??
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    38,275
    Re: Heater Question??
    Many people like to put in a bypass so that not all the water runs through the heater ... although most heaters have an internal bypass as well. I do not think you would want to completely stop the flow through the heater for long periods of time.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Water can run through the heater all the time, but you should also have a bypass to take the Heater out of the loop for maintenance etc. Some people like to bypass the heater when not in use to save internal wear and tear on the heat exchanger. The heater has a flow sensor, so it will not fire up without sufficient flow.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    You can do it either way, most pools don't have a bypass on them.
    Jul 2013
    Chicago IL
    83
    Thank you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's completely optional, but I like options. So, I had PB puit it in that way. I second blizzle on the no flow condition. Not good.
    Essential Links:
    Mar 2011
    441
    If you put in a bypass and isolation valves you should have at the very least a pressure relief valve installed into the heater. The heater can fire on on the closed valves then potentially explode if there is no where for the pressure to go.
    20X40 30,000 gallon gunite pool
