Results 1 to 16 of 16
Thread: Pool Timer
    Pool Timer
    Hi to all;
    We’re considering adding a timer to our pool system, probably an Intermatic T104R201 to control pump and heater.
    I've done some minor electrical around the house but am thinking this may be better left to a pro. Is there any kind of step by step guide to installing this unit? Does it require a separate fireman's switch?
    Thanks for any help,
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Pool Timer
    If it controlling a heater as well, I would be inclined to say yes. Your idea that it might be best left to a local electrician familiar with pools sounds best.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Pool Timer
    Replacing is a pretty easy job but installing from scratch for both the pump and heater is likely better left to someone who knows code and can make the installation safe for you and your pool users.
    Solar Blanket, Well Water, Borax Added. 68
    Re: Pool Timer
    OK, pool company says I don't need a fireman's switch with the type of heater I have (Ray-Pac Heater 266,000 BTU). They installed the heater.
    So what is the proper timer for my setup? We have 22V. at the pad.
    I was going to but an Intermatic T104R201 but maybe some cheaper would work just as well.
    Thank you,
    Gary R.
    Re: Pool Timer
    The regular T104 is a great timer.
    Re: Pool Timer
    OK, here's the timer I'm planning on ordering for 220-240V system just to control the pump::
    T104R DPST 24 Hour Mechanical Time Switch -208-277 volt
    - All metal construction. - Heavy-Duty lockable steel enclosure. - Tamper-Proof design eliminates vandalism. - Withstands temperature extremes.
    - Unbreakable. - Heavy-duty gear train. - Raintight NEMA 3R. - For: pools, spas, and fountains, electric water heaters, office, commericial, outdoor lighting, signs, etc.
    Description from Intermatic:
    The heavy duty mechanical time switch is designed for industrial, commercial and residential applications. Features a high horsepower rating that is ideal for loads up to 40 amps resistive from 120-volts and direct 24-hour time switch control of most loads. All models are equipped with one "ON" and one "OFF" tripper. The unit contains a 1-circuit standard On/Off Double Pole Single Throw 40 Amps, 4000 watt capacity, 208-277 VAC 60 Hz.
    Thank you,
    Gary R.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Pool Timer
    I like the plastic enclosures as they won't rust away like the metal ones will. Well, in about 20 years that is.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Re: Pool Timer
    Getting ready to have Intermatic T104R installed this week to control pump. I assume the On-Off switch on the timer would shut down the pump in the off position. Is there anyway to override the timer function to run the pump beyond where the trippers are positioned?
    Thanks for any info.
    Gary R.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Re: Pool Timer
    You can flip the switch on to manually turn on the pump.
    Re: Pool Timer
    Thanks for the reply!
    So, just so I'm clear, the trippers mechanically move the On-off switch to either the on or off position as the dial turns.
    Thank you,
    Gary R.
    DFW, TX
    24,492
    Re: Pool Timer
    That's right.
    Re: Pool Timer
    Now I get it!!!
    Gary R.
    Re: Pool Timer
    OK, one question about wiring. Currently, the pump and heater are wired on one 220 V.circuit and controlled with a toggle switch.
    It should be a simple matter to wire the T104 the same way with the pump and heater on terminals 2 & 4. Pump use 7.5 amps and the heater about 1 amp.
    Any pitfalls here?
    Gary R.
    Re: Pool Timer
    Even though a fireman's switch might not be necessary, I think that it's a good idea to use one to allow the heater a better cool down.
    Support the site
    Re: Pool Timer
    Pump and heater on one circuit is very common and works well with many heaters. There are a few heaters that require a fireman switch, and it never hurts, but does cost extra.
    Re: Pool Timer
    Thanks for all the help!
