Thread: New Skimmer
    Apr 2015
    East Wenatchee WA
    39
    New Skimmer
    Hi! So I was just browsing the online pool supply places for a new skimmer for the used 15x30 AG pool we are about to set up. This is not an intex pool and will be installed permanently. We are putting a brand new liner in and the skimmer is less than pristine, and needs new gaskets so I think its going to be less hassle to just put a brand new one in.
    My questions are: what is the difference between the wide and regular skimmers...
    the new one obviously has to be same size or bigger than hole already cut in pool wall so will a wide one even work?
    and do I want two?
    I have a monster sand filter and a 1.0 pump. Thanks..
    Also... the appear to be pretty cheap online... is that a bad thing or are they just not an expensive part??
    15'x30' oval AGP. 12000 gal. 1 HP pentair pump. 19 inch sand filter.
    Auto vacuum thing that works through skimmer. Solar cover.
    OLD 400ish gallon Cal Spa hot tub with two new pumps (ouch)
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: New Skimmer
    The most noticeable difference between the regular and wide mouth skimmers is of course the opening. Wide has a rectangular opening, and the regular is more or less square. Measure the opening in the pool wall, and see if you can match up some of the online offerings. If you want to go with a wide mouth, make sure the one you get is tall enough to fit the current opening, as some are smaller in that dimension.
    The other difference is how far the skimmer body sticks out from the pool. With a wide mouth, you may have to provide extra support at the rear of the skimmer.
    For AG pools, they all seem to be fairly inexpensive.
