Results 1 to 17 of 17
Thread: How to calculate amount of pea gravel/rock needed around pool
    Taylorbay's Avatar
    Jun 2014
    Heiskell, TN
    17
    We are about to enjoy our 2nd summer of our AG pool, last year we had it professionally installed and decided to do the landscaping ourselves, which we never got around to doing last year. i had some ideas but they didn't work out
    So... have a couple questions --
    1. pea gravel? river rock? or sand?
    2. how to calculatte amound needed for around pool, for instance i have a quote of 1 bobcat scoop of pea gravel = 4/5 of a cubic yard, the pool is 24' round
    help!
    24' x 52" Artesian Heritage AG / 15,000 Gal
    19" Sand Filter, 1 H.P. Pump Combo
    Installed: June 2014
    Frog System, Hard Plumbed
    Aug 2014
    Shallotte, NC
    693
    Re: How to calculate amount of pea gravel/rock needed around pool
    How wide and how deep will the gravel be?
    38,322
    How wide of a circle around the pool to you want the gravel? How thick?
    If you want 3' all the way around and 3" thick ... that would be 63.6 cubic feet .. which is 2.36 yards ... about 3 "scoops"
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    here is a link
    http://www.calculatorsoup.com/calcul...calculator.php
    figure out the area of your outer circle then subtract the area of your pool from that to get what the border is. Although that link above calculates a circle border for you.
    Taylorbay's Avatar
    Jun 2014
    Heiskell, TN
    17
    good questions lol
    I would estimate 2 - 3 feet, as far as dept, I'm not sure, what is normal?
    Aug 2014
    Shallotte, NC
    693
    You might want some sort of coping at the bottom of the slope, or you are going to be slinging gravel everywhere with the lawn mower....
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    1. River rock. Pea gravel will stick to your feet.
    2. v = pi(a^2-b^2)c
    where v = volume of rock
    pi = 3.14 or so
    a = radius to outer edge of rock
    b = radius to edge of pool
    c = depth of rock
    so, for a 24' diameter pool with 2 foot width of rock, 3 inches deep, a = 14', b= 12', c = 1/4'
    v = 3.14 x (14^2 - 12^2) x 1/4 = 40.8 cubic feet = 1.51 cubic yards (edited to correct typo)
    That's pretty close to two bobcat scoops. Adjust your numbers if you want a wider border or more depth. Use landscape fabric under rock to block weeds.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    DFW, TX
    24,497
    Quote Originally Posted by Taylorbay View Post
    good questions lol
    Usually 4"-6"
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Quote Originally Posted by sargent View Post
    2. v = pi(a^2-b^2)c
    pi = 3.14 or so
    c = depth of rock
    v = 3.14 x (13^2 - 12^2) x 1/4 = 40.8 cubic feet = 1.51 cubic yards
    Close, but not quite... typo there. 82.9 cu ft. 3 cubic yards.
    38,322
    Actually the 13' was the typo but the math was done with 14' ... the 40.8 cubic feet is correct.
    Just use the calculator that pooldv posted and forget about the math that apparently we are all going to mess up
    DFW, TX
    24,497
    Right!!!
    Taylorbay's Avatar
    Jun 2014
    Heiskell, TN
    17
    thanks everyone! I think now I actually have an idea of how much to get!
    Feb 2015
    Bardstown KY
    139
    If I may ask, how much were you quoted for river rock? We need to get some for our landscaping as well but I'm not sure what a good price might be. (Realizing this will vary some by area)
    And nice to see a fellow Steelers fan.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    I vote River Rock over Pea Gravel. River Rock stays where you put it. Pea Gravel wanders around the yard while you are not looking
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Mar 2013
    CT
    351
    Quote Originally Posted by elwood58 View Post
    What he said...
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    RIVER ROCK!
    Pea Gravel will stick to your feet and the weed eather and lawnmower shoots out them like .22 bullets! They hurt when they hit you. Bad!
    Divin Dave,
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Divin Dave View Post
    RIVER ROCK!
    Yes. Pea gravel = bad. Hurts like crazy on the next step when they stick on your feet. I broke a nice storm door one time with pea gravel with the weed eater just above idle. Glad it was tempered glass. Whatever you get, make sure you do a good border to hold it where it belongs.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
