- Apr 25, 2013
- 15
Opening up the pool for the first time since being built last year. The company closed the pool since they installed a safety cover. I took off all drain plugs and reattached the gauge on the filter as well as the drain cap. I filled the pump with water until the intake lines were filled. I set the filter to "filter" and turned on the pump. The pump is on but does not continue to suck the water from the pool. Does it need time to fill the filter back up to regain suction? I even tried running water in the pump while it was running to see if that would get the suction back.
Thanks for any help. Oh and the bright side is the water is crystal clear!
