Results 1 to 17 of 17
Thread: Installing Through Wall Skimmer, Intex Style Rectangle Pool
    Jul 2012
    San Diego, CA
    96
    Morning!
    I did a search on this, but could not find exactly what I was looking for. Hopefully someone can chime in.
    We are considering replacing our current rectangular splash a round pool with an intex 9 x 18 rectangular pool. If we do this, I would want to install a through wall skimmer. However, I have a few questions:
    Has anyone installed a through wall skimmer above the seam on a rectangular pool?
    Anyone install a through wall skimmer on a rectangular pool and willing to share how it is holding up?
    The water force on the walls is different for a round vs. rectangular pool, thus why the posts speaking about installing a through wall on a round pool were not able to answer these questions for me.
    Thanks!!
    Megan
    NEW POOL : 9 x 18, 48" deep - Bestway brand, 1 HP Intex 3200 Pump/Sand Filter Combo, Wanda the Whale, Hayward through wall skimmer (still in box)
    OLD POOL 5,100 Gallons, 9 x 19 used Splash a Round, Intex SWG, 1.5 HP Hayward Power Flow LX pump, Pentair Clean and Clear 150 sq. ft. filter, hard plumbed, Wanda the Whale,
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Installing Through Wall Skimmer, Intex Style Rectangle Pool
    G'day...
    I have the same pool.. Its great... I even bought the Hayward through the wall skimmer.... I've already cut larger intake and return holes and replaced all the fittings with the larger intex ones.... I have two suction hoses that connect into one, and one return....
    Because of my two suction fittings, I find I didn't have to install the skimmer, and I just use the regular over the wall intex skimmer attached to one of the suctions... Works brilliantly... If I want heavy duty skimming I just shut the plunger valve of the suction that doesn't have the skimmer attached to it and it pulls more water through it.... To be honest, when I cut the new holes for the fittings, it felt ok as it was a reinforced part of the pool, cutting a new hole in the side of the liner with only the gasket and skimmer holding it there, worries me somewhat... Many have done it, don't get me wrong, I just found I didn't have too.....
    You can check my thread if you want... It is a little long....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    Im selling a new through the wall skimmer on this site's classifieds in the coffee bar
    16' x 48" 5000 gal. Intex Ultra Frame AG Pool, Los Angeles, CA
    Hayward Full-Flow Cartridge Filter System with 2 Speed Power-Flo Matrix Pump,
    Intex SWG, Intex Wall Mount Surface Skimmer, Solar cover & Solar Roller,
    Confer Plastics A-Frame 7200 Adjustable Roll-Guard Safety Ladder,
    Kokido SkoobaMax Vac, Custom Canine entry & exit ramps,
    Dec 2011
    Biggleswade, UK
    37
    Yes I did and its still holding strong.
    Through Wall Skimmer on Rectangular Intex Ultra Frame UPDATE
    Jul 2012
    San Diego, CA
    96
    Thanks Barlidge!! This is exactly what I was looking for! We just hard plummed it without the through wall, even though I have it here in the box, because I was too nervous. I wonder if I could have the upper screws going above the seam, and cut the opening just below the seam line to keep some water height. Hm.
    AnnikaF's Avatar
    Apr 2015
    Southampton, UK
    36
    I have a widemouth skimmer installed, upper screws above the seam and cut just below the seam line. Works like a charm, go for it
    Chris - Annika's papa
    9x18 Intex ultra AGP 4500 gallon, 3200gph intex 1hp pump with 16" sandfilter, abs hardpiped, hayward skimmer, Intex SWG, 11kw heater, LaMotte ColorQ Pro 7 test kit.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Do you lose very much in water height?
    AnnikaF's Avatar
    Apr 2015
    Southampton, UK
    36
    Nope, i'm right up to the seam line/top of skimmer opening. A couple of cannon balls and evaporation and i have to refill...
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Could you post a picture of your Skimmer? Thank you
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    AnnikaF's Avatar
    Apr 2015
    Southampton, UK
    36
    Quote Originally Posted by Piolin View Post
    Jun 2015
    Stockholm, Sweden
    250
    One from the inside too please?
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    AnnikaF's Avatar
    Apr 2015
    Southampton, UK
    36
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Thank you
    Jun 2015
    Stockholm, Sweden
    250
    Thanks Annika, looks really good. The gray colour matches the pool nicely. I have only seen them in white before. Where did you get it?
    AnnikaF's Avatar
    Apr 2015
    Southampton, UK
    36
    Tjenare, hur mår ni bought it on ebay, pond skimmer, half price and exactly the same as the pool labeled..
    Here you go.. Standard Wide Mouth Skimmer for Above Ground Pool | eBay
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Have just replaced (this week) a skimmer on my Doughboy above ground pool. The pool was built in 80s and the skimmer was original. I owned it since 2005 and abused it left and right, letting it freeze in Jan as I swim in the winter and use circulation to keep it from forming ice until it drops down to single digits when I know it won't handle it anymore and disconnect the pump and close the skimmer. So this winter (I did close it and emptied the bucket) after being just fine while in use, it then cracked (found it a week ago), hence the replacement.
    Problems: outside developed oxidation that broke the seal so after install it leaked. Wirebrushed it, sanded and used silicone caulk, on the outside. The leak had stopped. The process is easy.
    God lykke.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    Jul 2012
    San Diego, CA
    96
    Thanks for the photos Annika!!
