Thread: High CYA and pool store still wants me to use pucks.
    Apr 2015
    Southern Cali
    30
    My CYA is at 150. Shoul I be using liquid chlorine until my CYA levels get balanced? The pool store, obviously, told me I needed to use 3 - 3" chlorinating tablets, to make a buck off me I think. From my understanding, the tablets leave CYA in the water. Something I don't want right now. Should I use liquid chlorine for now?
    16,000 gallon, IG, Plaster, pool and spa.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: High CYA and pool store still wants me to use pucks.
    Welcome to TFP Mendez
    Probably yes, but first is that 150 cya number from the pool store? Also, yes the pucks add Cya to the pool when you use them.
    My first suggestion is to get a proper kit, and test it yourself. Without a good number on that, and your current FC, it will be impossible to give you the correct numbers to use. We also need to know about your pool. Can you please add that data to your signature line? It helps us answer you much quicker, and with the best advice.
    Essential Links:
    Welcome to TFP!
    With CYA that high, I would replace water to get the CYA level down to something more reasonable. And, yes, switch to a chlorine source like liquid chlorine that is not constantly adding more CYA.
