Thread: Salt too High
    Apr 2015
    Burlington, NC
    1
    Salt too High
    Hi -- I added 160lbs of salt to my pool and suddenly the red high salt light appears. Before this it said check cell and no salt reading. I did that (cleaned cell) and then thought I should add salt since it was the first time i added it since June of last year. How do I get this corrected?
    Elvis2009
    Re: Salt too High
    Welcome to TFP!
    You should turn off the SWG for 24 hours after adding salt, leave the pump running for those 24 hours, and then turn the SWG back on and let it measure the salt level to see what it is.
    Salt levels in the first 24 hours will fluctuate wildly as the salt mixes into the pool water.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Salt too High
    Welcome to the forum Elvis
    Please add your pools info into your signature and outlined here - - > http://www.troublefreepool.com/conte...etting-started
    Need the information that would be in your signature to answer the question.
    Solar Blanket, Well Water, Borax Added. 68
