Results 1 to 7 of 7
Thread: "Intermittent" leak? Relation to water table??
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    I won't bore you with all of the details but i have had an intermittent leak since the winter of 2013-14.
    I lost a foot or so of water over the winter that year. My liner floated up. In the spring i filled it back up, the liner went back into place with the exception of a small wrinkle or two and everything was fine for a solid month.
    At that point it started leaking and i lost a solid 1/2 to 1 inch per day. It leaked whether the pump was on or not. I let it go and it leaked down well below the skimmer and stopped. I couldn't find any sign of a leak at that level. I filled it back up and it didn't leak for a period of time.
    So basically nothing makes sense to me. It really seems to be intermittent and perhaps something with the liner?
    My last question is if i had a leak in the main drain line would a high water table stop it from losing water??
    Any suggestions?? I dealt with this all last summer and added so much water i never got the water temp over 76!
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Re: "Intermittent" leak? Relation to water table??
    If there is a leak anywhere below the pool water line (liner, plumbing, anywhere below that level) the pool depth with try to follow the water table depth, leaking when the water table is low and even filling up when the water table is high. The pool will stop leaking when it gets to the water table depth, or the leak depth, whichever is higher.
    Because the liner floated we know that you have a high water table at least part of the year.
    So it all makes sense to me, though nothing here tells us much of anything useful about where the leak actually is.
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by JasonLion View Post
    So where would you start in looking for the leak??
    Haywood Sand Filter
    Vinyl Liner
    A leak detection service might be a good idea. They should have a system that can narrow down the location with something resembling a radio direction finder.
    Nov 2011
    Albany, NY
    495
    I was afraid i would hear that.
    One last question though. Two days ago i added about 8 inches of water which presumably would bring it way above the level of the water table since it has been sitting at the same level for several weeks. It has not dropped a bit in two days.
    Would that point toward a hole in the liner that could get plugged as is shifts and then open up when it shifts again??
    Haywood Sand Filter
    Vinyl Liner
    That is certainly a possibility.
    It is difficult to say much of anything for sure without pinpointing the leak.
    Nov 2011
    Albany, NY
    495
    Turns out i had one or two serious gashes in the liner and a number of minor ones that are most likely from my old vacuum head.
    Anyone near Albany NY in need of a guy to find leaks contact me because the guy i used was fantastic!
    Haywood Sand Filter
    Vinyl Liner
