Thread: Removing liner - what else to do
    Jun 2012
    Blaine, MN
    106
    We will probably be removing the liner when we have someone fix the rim/sidewall issue.
    At that time I am hoping to have the floor smoothed out. What can we do to prevent the uneven floor happening in the future?
    Would you recommend adding foam around the walls to help keep the water warmer and possibly extend the swimming season?
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    Jun 2012
    Blaine, MN
    106
    Re: Removing liner - what else to do
    Any thoughts???? The floor was smooth the first year and slowly developed weird dips that we attributed to moles. The pictures show what I believe to be settling of some kind around the support system.
    blondemarcello
    Minnesota
    Casey's Avatar
    SW PA
    10,438
    Foam on the walls does nothing to keep the pool warm. You'll lose all your heat from the water surface through the night. If you want to keep the pool warm, cover the pool at night n don't run the pump at night.
    Is that wall out of track? If it is, the pool is not level. The only way to fix this is to 're level the pads the post is sitting on that are not level.
    Once you address that issue, then you can work on the sand base.
    Jul 2014
    Oakbank, Canada
    389
    Quite a few folks insulate their pool walls, with varied success. Some find it works great, others so-so. To each their own in the end. Covering the pool at night helps immensely, and using a solar blanket during the day when not using the pool also helps. Leaving the pool uncovered just lets the heat escape.
    Yeah, those look like mole or mice tunnels for sure. I would say to take some of the sand out, leave only a thin layer, and than lay foam sheets down instead.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2012
    Blaine, MN
    106
    It's hard to tell from the picture of the pool floor but the settling is worst around the supports. You can actually see/feel the support shapes. Will foam stop this from happening in the future? What type of foam would we use?
    The track is dropped down between the supports, if I remember correctly. Would uneven support bases make the track drop in the middle? I am having a hard time finding someone to come out and give me an estimate for fixing this.
    blondemarcello
    Minnesota
