Results 1 to 8 of 8
Thread: Is 4 hours of pumping a day a general rule of thumb?
    Aug 2014
    Oviedo, FL
    47
    Quote Originally Posted by JasonLion View Post
    Roughly four hours a day, ideally split into a couple of different segments at different times of day.
    The speed should be set to the lowest speed where the skimmers work well and if you have a heater, the heater is happy with.
    Is this a general rule of thumb? I'm also interested in a schedule for my setup - I have a Pentair Variable Speed IntelliFlow where max RPM is 3450. Builder told me 8-10hours on 2200RPM-ish...
    10,965 Gallons IG Aqua Pearl Finish pool, Pentair C&C RP 200 Sq Ft, Pentair Intelliflow VS Pump
    Opened 03/27/2015, TF-100 Test Kit, Spa, Double Flagstone Spillover, Pentair IC40 SWG, Pentair 125K Heat Pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Variable Speed pump schedule?
    For this forum, it is a general rule of thumb. It is based upon member experiences as well as the run time study in my signature which shows that there is little water quality improvement after 2 hours of run time. 4 hours is conservative because some pools might need more.
    Mark
    38,251
    I will just leave this here for your future reading: Determine Pump Run Time
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I would start with running it 2 hours in the AM and 2 hours in the PM at 1100rpm. If it doesn't stay clean over a series of days then increase the run time by 30 min and see how it goes. If it is spring or fall and you have trees then you need to run it a lot longer during those times.
    It is really about trial and error to find the least, or close to the least, amount of time to keep it clean. If isn't clean run longer, if it is try running shorter. But, you electricity consumption will be so much less with the VS pump you might not mind running it.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Is 4 hours of pumping a day a general rule of thumb?
    Also, you don't have to run the pump so that every last leaf and every last piece of dirt is picked up. That is purely optional and only about your own tolerance for debris.
    Mark
    Aug 2014
    Oviedo, FL
    47
    What about for new plaster pool? Builder recommended that I brush every day and leave the pump run high for 8 hours each day for the first 30 days? Thoughts?
    With fresh plaster you typically want to run 24/7 for the first week and then something like 8 hours a day for the rest of the first 30 days, and then after that cut back to roughly 4 hours a day.
    Also, it is good to do whatever your builder says, even if it doesn't make a lot of sense, to insure your warranty will not be threatened..
    38,251
    For new plaster you should probably run more often to clear out the plaster dust during curing. The rest of this discussion is for normal maintenance mode.
