Results 1 to 19 of 19
Thread: Removed Heater, What can I use to reroute the plumbing
    May 2012
    Dallas, Texas
    28
    Hello Mates,
    The attached pictures are worth a 1000 words that I can't seem to come up with to describe what I need.
    Basically, I need to know where I can get a prefabbed PVC fitting to plug the holes in my pool plumbing....Or....Do they make such a part.....?
    Mose
    16,000 gallon, IG, plaster, filter= DE 60 sq ft, Pump= Hayward EcoStar SP3400VSP variable speed, Build date= 2004, SPA, Heater= Pentair natural gas 400k BTU, Cleaner= Hayward Navigator (Pool equipment installed 2 feet above pool water level)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Removed Heater, What can I use to reroute the plumbing
    The easiest thing is to cut the pipe unless the unions are threaded in. After cutting, simply loop those two ends together and let the flow remain that way. You don't want to plug them and create a dead leg.
    Essential Links:
    May 2012
    Dallas, Texas
    28
    I'll give that a try. Thanks Mate.
    38,463
    If the heater is permanently removed, I agree just cut off what you need to figure out a way to connect those 2 lines.
    If you may put the heater back at some point, that may be more tricky as I am not sure you can find the mating union parts that have the same threads.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I assume you also have bypass valve to take that route completely out of the picture? If so, why not leave it as-is, so you can replace the heater in the future.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    38,463
    There is no bypass line. You can see it come right out of the filter.
    May 2012
    Dallas, Texas
    28
    Yes, you are correct there is not a bypass, which is something I intend to change when the new heater is plumbed in (when I find the right deal on a 400k BTU heater).
    I followed the majority advice and just cut that sucker off (both open ended pipes). Went to Home Depot and got the necessary PVC 90 degree elbows, straight pipe, primer and glue and slapped them on.
    Thank You all Again for the good advice....mose
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Excellent, I was hoping you'd do that. When you get the new heater, it should come with all the proper unions. Mine did anyway, put in last year. Good job man.
    Essential Links:
    May 2012
    Dallas, Texas
    28
    Here is a pic of the plumbed Heater pipes.
    I ran into another issue. I turned the breaker back on but I'm not getting any electricity to the pool equipment. It seems as though removing the heater has caused an issue with the electrical system.
    I left all the wires hooked up so everything will be ready and in place for the new heater but I have not ordered the heater yet. I want to be able to run my pool while I research the new heater.
    Any ideas on this electrical wiring issue.....?
    Check the breakers and make sure they all actually turned on. If you have a sub-panel for the pool, also check the breaker for the sub-panel that is in the main panel.
    Apr 2015
    Los Gatos, CA
    22
    mose,
    What is that last picture you posted? Are those the wires that were previously attached your heater, that are coming from somewhere else in your pool equipment?
    A few things:
    1. How many breakers are there for this equipment? Was there a separate breaker for the heater?
    2. Even if you are absolutely sure that the wires in your picture are connected to a breaker that is turned off, it is dangerous to leave them exposed on the ground. You never know when someone might turn on a breaker accidentally. Ideally I'd like to see them wire nutted and sitting inside a grounded outdoor rated junction box.
    3. Can you trace the wires and figure out where they are coming from? It is possible that the power was fed through a box on the heater, to other equipment (although I'm not sure why they would have done that).
    -Carl
    25000 Gallon Pebble pool/spa, Intelliflo VS, Pentair IC-40 SWG, DNS-60 DE Filter, Max-E-Therm 333k BTU heater, Polaris 280
    EasyTouch, ScreenLogic, Intellibrite
    Homemade AutoFill (1/2" Hudson Valve), 20-70 GPM flowmeter (Blue-White F-30200PR)
    May 2012
    Dallas, Texas
    28
    After removing Heater, yesterday I turned the on the breaker but got no electricity to my equipment. I then turned the breaker off, traced the wires back to the Hayward control panel and disconnected them. I then turned the breaker back on and again still got no electricity to the pool equipment.
    1. There was a single breaker box added for the construction of the pool. That breaker box is located on the outside wall next to the pool equipment.
    2. Not knowing what to do with the wire ends I capped them, wrapped them in plastic and ran them into an enclosed wooden box. They are still in the box but also disconnected from the Hayward control panel.
    3. I checked all breakers in and outside of house and I am still not getting power to the equipment. Three pic's of equip, fence behind me so I couldn't get everything in one picture. Breaker box is closed in one pic and opened in the next.
    This really has me stumped.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    What is the model # of the control panel ??
    Is there some safety where the panel sees the heater as an open circuit and locks power out of all the equipment ??
    Solar Blanket, Well Water, Borax Added. 68
    You need to get a meter and trace back until you get to something that has power. Where ever it is, the space between the last location with power and the first location without power is the source of the problem.
    Apr 2015
    Los Gatos, CA
    22
    2 more questions:
    1. Is there power at the outlet below the panel? It is a GFCI, can you reset it?
    2. Can you take a picture inside the Hayward panel?
    -Carl
    It looks like the power is coming in from the square D panel on the right via the conduit that goes to the bottom of the siding and off to the right in the pic. If that breaker is off the whole system could be off.
    Building: 30'x15' freeform w/spa and waterfall, 16k gallons, AA Quikclean in-floor cleaner and Quikskim, Pentair Easytouch 8 w/IC40 SWG, Intellabrite lights and bubbler, Sta-rite Intellipro VS, Sta-rite 2HP Waterfall pump, Sta-rite 400k gas Heater
    May 2012
    Dallas, Texas
    28
    Quote Originally Posted by Kiss4aFrog View Post
    Here are some pics of the board. Let me know if this gives any clues. I do know that the Control panel is obsolete and I want to replace it next month but for now I just need to get the pump and filter to cycle. Any Ideas on how to get power to pump and bypass everything else.
    May 2012
    Dallas, Texas
    28
    Apr 2015
    Los Gatos, CA
    22
    Sorry mose, its hard to debug remotely, and I'd hate to have you get into trouble by taking our advice without being there. Do you have someone electrically inclined who could help you with this? If you just want to be able to run the filter pump, and someone has the right tools to determine which wires are live, I expect they could bypass everything inside the hayward box and just wire the pump directly to the incoming AC Lines coming from the breaker. Then the pump would run any time the breaker is on. Make sure that they pay attention to the voltage -- the box has 220V in it, and the pump may be 110V or 220V.
    -Carl
