Results 1 to 15 of 15
Thread: Upgrading equipment, does rest of the setup look ok?
    Mar 2015
    San Ramon, CA
    20
    I am upgrading the equipment thanks to equipment advice i got from you all in another thread. Can you guys please see if anything else look not alright so i can take care of it while i am at it. Posting Images.
    New Pool Owner, 19K Gal Plaster pool with Spillover Spa, Taylor K-2006C Test Kit w/ Speedstir
    Pentair Quad DE 60 sq.ft, Intelliflo, Pentair Warrior Suction Cleaner
    400K BTU NG Pool Heater, Single Skimmer(Lid Missing)
    Mar 2015
    San Ramon, CA
    20
    Re: Upgrading equipment, does rest of the setup look ok?
    38,237
    If it is working, then it is fine.
    There are two attitudes. If it ain't broke, don't fix it. Or: Replace worn out parts before they cause a problem. I'm solidly in the second camp, and would start thinking about replacing a lot of that equipment, as a fair bit of it looks more than a little past it's prime. It looks like you still have some copper pipe, which would be at the top of my list to replace.
    38,237
    I did almost mention the copper pipe
    The heater looks in decent shape, the electrical box is rusted on the outside, but the inside looks fine. You are already replacing the pump and filter. The only thing left is the spa blower and that is far from causing a real problem if it fails.
    Mar 2015
    San Ramon, CA
    20
    Dont know how easy will be replace copper return underground piping. But heater, pipe section could be replaced with pvc 2". If you say so?
    I will primer paint the electrical box get a faceplate for it if i can figure where to get one? And replace weather stripping. I dont have any check valves in my system? Where would you suggest one? Want to put heater bypass when that pipe is replaced.
    Mar 2015
    San Ramon, CA
    20
    Does the older valve look like it needs to be replaced soon? The return valve is jandy never lube.
    38,237
    Why do you think you need a check valve?
    Mar 2015
    San Ramon, CA
    20
    I thought the prev owner might have missed it somewhere i saw some equipment pics here on tfp had a jandy clear checkvalve.
    38,237
    They are only needed in special circumstances. Although, one of them is if your spa is raised above the pool. Is yours?
    Mar 2015
    San Ramon, CA
    20
    Thanks for all for advice pool equipment upgrade is done. Got rid of the trees next to the pool, that helped, a lot. I have high CYA right now. maybe 140 or above. Have to do a partial drain, unless you guys say anything else. 10k Gallon refill is going to cost $75 not too bad and may save me chlorine. I have clear water right now but sometime a small patch of algae forms. Keeping up with chlorine demand right now. and it drops to 12, and i move it back up to 17. Please advise.
    Thanks
    38,237
    Replacing the water to lower the CYA is the best plan forward.
    Mar 2015
    San Ramon, CA
    20
    Should i SLAM once i replace water? Also i was thinking about using something like a laundry sink draining to the sewer cap opening to wash DE filter cartridges, has someone tried something like this?
    38,237
    After you fill, circulate for an hour and retest the CYA and pH and then start to SLAM.
    Mar 2015
    San Ramon, CA
    20
    Thanks. Will post pictures soon.
