Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: DIY Propane Firepit
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    DIY Propane Firepit
    Hey guys - we just signed for a new pool - and we are designing the decking so that we can put a propane firepit in later (rounded decking near the sap to fit the pit and seating around it. (Have to cut costs somewhere). We do not have gas out here in the country - so propane is our only option for spa heat and firepit.
    With that being said - has anyone done their own? I know the PB mentioned that they have to order 10% more mossrock and flagstone than they need for the pool - so I am hoping to snag all the leftovers so my firepit will be made out of the exact same materials. They are going to allow us to have it plumbed when they pour the decking - so it should be ready to go. I think the quote for them to build it was $1400. Just doing a quick search - looks like I can buy all the materials (other than the stone) for about $400. Is it $1000 worth of work? I don't want to get in over my head . . .
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    38,248
    Re: DIY Propane Firepit
    Depends on how you want it to look and what experience level you have at making something like that.
    Pretty cheap to stack some cinder blocks around a pit to sit on
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    When I was doing the cost-benefit analysis for my fire pit, I quickly realized that my PB could give me a turnkey fire pit for less cost than I would be able to run the gas line later. In my case, I saved a lot of money since they were able to run all the fire pit gas lines in the same trenches that they were using for the gas line to my pool heater.
    As long as you have a fairly straight-forward way of running your propane line, I don't think it should be anywhere near $1000 worth of work.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Texasrebel's Avatar
    Mar 2015
    Conroe/houston
    28
    Propane is not like natural gas, use extreme care in selecting the proper materials to use....also btw if you're using a propane fueled pool heater, demand your pool builder give you the license info of the plumber doing it. Do not let his "guys" do the job. We were just out on an insurance claim the other day were it was denied because the pb did not use a licensed plumber.
    IG gunite/plaster 9,200 gals-with 7x7x1-1/2 splash pad with bubblers.
    3/4 hp hayward super pump for bubbler and water fall-1 hp hayward super pump for filtration
    24" hayward sand filter.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Thanks guys! My PB absolutely uses only licensed (and bonded) workers - he went through the entire spill about that is why his price is higher than most PB in my area. However - he is going to allow me to have the Propane people (who install the tank and run the lines at the time of install) - run the lines before they pour the decking. He said I will have a 3 day window we can do it. So that the propane will be plumbed and ready to go for the future firepit. He also said, that they could "sleeve" it if we weren't ready to run the line at the time of the pour. Now from what I read- I think that means they run like a pvc pipe to the area so that the propane line can be slid under the decking later - but I haven't asked him specifically.
    We don't have the option of gas out here - we are way out in the woods and electric didn't seem like a good option after talking with friends who heat their spa with electricity. Seems like it takes forever to get it warm.
    The inserts for the firepit - don't seem too complicated - I have no idea how we would do the stone work around it - but google is my friend. Ugh. I do wish I could just say do it all - I am made of money! My husband already thinks I said that I am 15K over budget right now . . . and he won't let me go any further . . . maybe I could find something to cut in my extras and have the firepit complete instead . . .
    ~Wendy
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Did you take a look at going with a heat pump at all ?? It's more expensive up front but so much cheaper to operate than LP ??
    https://www.google.com/#q=pool+heat+pumps
    Solar Blanket, Well Water, Borax Added. 68°
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    We did - I want the ability to heat my hot tub quickly and the heat pump just doesn't do it as fast. We won't be using the heater for the pool - only the hot tub and I loved the idea that I can turn it on and get in quicker!
    ~Wendy
    Texasrebel's Avatar
    Mar 2015
    Conroe/houston
    28
    In the state of Texas the lines from the tank can only be run by a licensed plumber...propane company can do no more than set the tank and make the single connection to the lines the plumber installed. I own and run a plumbing company that covers all of Montgomery county...I'm extremely up to date on plumbing code and laws. Other than that we've hooked up a ton of fire pits there are some really cool things you can fill them up with....my fav is crushed glass!
    Quote Originally Posted by Sunbaby View Post
    Thanks guys! My PB absolutely uses only licensed (and bonded) workers - he went through the entire spill about that is why his price is higher than most PB . . .
    I bet you if you ask for their license info he stutters...lol
    Apr 2015
    Mt. Airy, MD
    1
    Was thinking of a DIY propane fire pit and here is what I have found so far
    http://www.moderustic.com/How-To-Bui...-Fire-Pit.html
    Feb 2011
    Petaluma, Ca
    665
    I'm in the process of building one, it has a aluminum base enclosure that will be powder coated. I poured a concrete ring for the top, 48" od x 24" id, and polished it, looks pretty good but I'm doing another to get it better ( I hope). The base covers a 5# propane bottle. We made our own burner from sheet stainless. I'm waiting on some "glow glass" that I will pour into the next top, hopefully it will be complete in about a month. I may use the 1st top to make a wood burner somewhere else on the property. I really want a solid concrete natural gas with a polished top, that's in my plans.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Hey Rebel - do YOU do Firepits? Can I get a quote from you? My PB actually gave me a list of all the people he uses and their info - I wonder if I should look it all up to verify everything. Ugh. So much work. I just wish people would be honest
    Thank you Restonledo - I will visit this site when I finish up work tonight!
    Bobby - that sounds really complicated. I was thinking of just buying a kit - and attaching it to the gas line that is going to be already plumbed - and just building the facade around it with the flagstone and mossrock. (Haven't really looked into that part yet). I was thinking glass fire stones - they are so cool looking - and the darker colors cover the soot from the propane.
    ~Wendy
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Here are a couple of the kits I was looking at - but we have an outdoor store in Conroe that Ive heard sells kits - I want to go in and look at what they have and see how difficult it would really be.
    http://www.ultimatepatio.com/item_na...m_2875632.html
    http://www.ultimatepatio.com/item_na...m_2885412.html
    ~Wendy
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Hey Rebel - my PB lists the who he uses and gives their License# - he uses a Master Plumber with the license #18230. Do you think when they get here to do the work I should verify that is who is here? Not sure what I should do to verify?
    ~Wendy
    Feb 2011
    Petaluma, Ca
    665
    It is, I love to go overboard, I started this in 10-2013, and I'm just getting near completion. I got hooked on the polished concrete with glass in it, looks really good. It will have the glass covering the burner also.
    Texasrebel's Avatar
    Mar 2015
    Conroe/houston
    28
    I tell people all the time to have no fear when asking contractors for their licenses while on jobs. A licensed plumber, electrician etc should have no problem showing you their license.
    https://licensing.hpc.state.tx.us/da...or=beca78a.0.4
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Bobby, I hope you post lots of pics!
    Rebel, do you do firepits? Maybe I can get a quote?
    ~Wendy
    Texasrebel's Avatar
    Mar 2015
    Conroe/houston
    28
    We only do the gas work....run the lines, valves, ss rings etc.
    Whatever you do make sure you have a great drain and cover. Two of the most over looked items. I can tell you this though for the install and kit we charge less then just that kit cost.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Oh wow! Ok. Cool. Maybe it's the stonework that is so pricey?
    I didn't real I needed a cover. I was thinking that the pan had drain holes so I cou keep it uncovered. Good to know! TY!
    ~Wendy
    Feb 2011
    Petaluma, Ca
    665
    here are some pics of the under construction pit.
  20. Back To Top    #20
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    AMAZING! Mine would be very small and rinky-dinky compared to that monster! That is going to look awesome!
    ~Wendy
