Thread: Replacing Skimmer
    Replacing Skimmer
    Hello All,
    I haven't been on here in a while, but I sure could use your help again. I need to replace my skimmer, and the original pool installer has no idea or records of what was installed. So instead of looking at replacement parts, I am just going to replace it. Can someone give me a recommendation of what brand or model would be sufficient. I have a 24' x 52" Sharkline ABG. I also have a 1hp Hayward 2 speed pump with a Hayward 300b sand filter, which were recommended by this forum and have worked great! My current skimmer measurements follow.
    * Outside - Basket side: 13 5/8 L x 7.5 H
    * Inside - Pool Side: 14 3/4 L X 8.5 H
    Thanks
    Daniel
    24' / 52" sharkline AG with Hayward 24" Sand Filter, Hayward Matrix 1 HP / 2 speed pump, and Hayward Aquatrol SWG.
    38,271
    Re: Replacing Skimmer
    Try adding a picture of your current skimmer: How To Post Pictures tutorial.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    This one is a popular replacement. It is cheaper than the parts in many cases.
    Hayward SP1091WM Dyna-Skim Above-Ground Pool Skimmer Kit Hayward
    -- Guy --
    Casey's Avatar
    SW PA
    10,428
    You can not use a Hayward skimmer box on a Sharkline pool. Call poolsupplyworld n order the skimmer through them. Its a Waterway skimmer box.
    Hopefully these photos are sufficient. If not, I will take some more this evening. The photo may not show this clearly, but inside the skimmer, there is a notch which helps to secure the basket. The basket and vacuum attachment both share this notch as well. The notch is what is giving me trouble when attempting to use a generic basket or vacuum attachment, since both of mine are no longer usable. The flap that allows water in and out, but helps keep the debris in is also broke (I'm certain there is a name for this flap, but I can't think of it right now). Again, I really appreciate your help.
    Daniel
