I agree the wording is questionable. Although I am sure what they meant is if it looks like it was hit with a sledge hammer then they are not likely to warranty water damage due to a failed seal.
I think it also heavily implies that if there is visible damage due to corrosion from chemicals, calcium buildup, or the like that will affect the warranty as well.
The scheduling being only for short vacations makes sense I guess... except for 2 things:
1) Nowhere in the website, brochures, or marketing videos does it mention that
2) What is the "bin is full" indicator light for? If you're pulling the thing out of the water every day, you might as well open the container and at least check to see if it's full. If you're on vacation, there's no one to see it...
I get the feeling that they're working their way towards a pretty autonomous machine that you can keep in the water all the time and run on a schedule, like you would a Roomba, but realize they aren't quite there yet, so it's mostly marketing fodder right now that they aren't really willing to stand behind if it doesn't work right and leads to a failure.
robl45 said:
as I said, if the robot is broken is spinning in circles is about the only time you should have to do that with the cable. Possibly once every 3 months and good luck with that unless you have a huge yard to stretch it out and leave in the sun.
Thankfully, my yard is big enough that I could stretch the cord out and leave it in the sun (well a lot of it in the sun anyway)
I still can't see myself doing that with any frequency
mas985 said:
Given the availability of pressure side cleaners that don't require boosters, why would you even consider it? It uses a large amount of energy and it is just one more thing that can go wrong.
I have no experience in such things, but I don't think that the pressure coming out of my returns would be enough to power anything. I did, however, recently have a new, dedicated suction line plugged in, so I can effectively use a suction side cleaner without sacrificing my filter now. Because of that, I'm seriously considering a ThePoolCleaner. They get very good reviews and seem to be substantially cheaper and less prone to failure than any robots. What I don't like is that I don't think they're as good at climbing walls, cleaning the pool surface, or scrubbing...
