Thread: CYA- to add or not to add
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Hi all!
    Hard to believe this summer has once again whizzed on by! I have a quick question about my CYA levels. Since I plan on closing the pool for the winter around the end of this month.
    I normally keep my level at 50ppm. I tested it today and it was reading about 35-30ish. So Should I add more CYA or not?
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    30,431
    Re: CYA- to add or not to add
    You would probably only use an extra $10.00 worth of chlorine. I would leave it alone and adjust in the Spring.
