Results 1 to 12 of 12
Thread: Looks like I gotta slam my pool
    Jan 2015
    San Jose, CA
    237
    For the past couple of days, I'm seeing green algae build up on the side walls after a couple of days of scrubbing. I don't want to blame the neighbor for their kids throwing a bunch of junk in my pool but I'm going to blame them anyways cause for 5 weeks I had no problems.
    My reading as of 15 minutes ago
    Temp - 58 Degrees
    FC - .6
    CC - 1
    Ph - 7.8 (just added about 70oz of MA)
    TA - 140
    CYA - 40 (this has been my most concern but I'm relief to find that it's in check now)
    CH - 350
    I have 2G of 10% chlorine here, according to the chart, I'll need to bring my FC up to 16 so that's 3gal of chlorine so I'm going to have to buy a couple more jugs. Would 4 jugs be good or buy 6?
    Does MA store well? Maybe I'll pick up another jug or two while I'm there.
    oh ****, one more thing my cheapie test kit only goes up to 5 for chlorine. Anyway around this?
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    38,475
    Re: Looks like I gotta slam my pool
    You need 3 jugs (assuming you math is correct) to just get to shock level ... then you need to MAINTAIN it there ... you are going to need more than 6 jugs.
    Review the ShockLevelAndMAINTAIN Process if you have not recently.
    MA will last a long time.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by dannieboiz View Post
    Temp - 58 Degrees
    FC - .6
    CC - 1
    TA - 140
    CH - 350
    No way around the FC test. You must have it, but you are getting those other numbers with something. Which kit is it? If it's a good one, you can order the FAS/DPD Free Chlorine kit alone.
    Essential Links:
    Jan 2015
    San Jose, CA
    237
    W/O knowing I purchased a home depot brand http://www.homedepot.com/p/Unbranded...2364/203796265
    Does the TF-100 cover this test or do I need to buy the FAS/DPD Free Chlorine kit separate?
    SF Bay
    38,475
    I would just get the TF-100 (which includes all you need) and toss that "unbranded" kit.
    They may still have free shipping if you get one of the options with the TF-100.
    Really all the kit you do test for is : TC, pH and TA ... missing FC/CC, CH, and CYA ... and no real need for the acid demand.
    Jan 2015
    San Jose, CA
    237
    I went ahead and order the TF-100 will be here next Monday.
    I guess they're not much I can do in the mean time? Maybe I'll go clean my grids.
    SF Bay
    Jan 2015
    San Jose, CA
    237
    I got a box of HTH super select shock treatment. I know powder is bad if it has Dichlor or TriChlor but this stupid bag only list 56.44% Calcium HypoChlorite and "Other" Ingredients 43.56% LOL WTH is other ingredients? Where do I find the whole list of the other ingredients?
    actually found the other ingredients, does this look safe to use?
    http://www.kellysolutions.com/erenew...0_40_28_AM.pdf
    FYI I contact HTH and they said it's unstabilized. So it doesn't raise CYA levels. I know you guys hear hate anything powder but with that said should I use it while I wait for the test kit?
    SF Bay
    38,475
    It is cal-hypo ... it adds CH along with the chlorine. I would not want to add CH any faster that it will due to evaporation, but if you get a lot of rain, it could be fine. Usually liquid chlorine / bleach is cheaper if you look at the ppm of FC it adds.
    Jan 2015
    San Jose, CA
    237
    We're expecting some rain tonight and through tomorrow. Not sure if it's enough to offset. I kind of don't wait to leave it untreated for the next week.
    SF Bay
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Powder is fine for certain things and situations. We only dislike the fact that many people selling them don't educate the buyer about the side effects of using them.
    Essential Links:
    Just as an FYI, the Home Depot kit you linked to is actually pretty good (for what few tests it provides). I bought the same kit the weekend we moved into our house (had a K-2006 on order). When I got the Taylor kit, I compared the readings (FC and pH) of the two kits and they were pretty much spot on. After you're done with your SLAM, it wouldn't be the worst thing in the world to use the HD kit for your daily tests and use your TF-100 once or twice a week as a sanity check.
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    Jan 2015
    San Jose, CA
    237
    Quote Originally Posted by bigglesworth View Post
    I was gonna do the exact same thing but since you already did the comparison, that'll be one extra test that I wouldn't have to do.
    SF Bay
