Thread: Extending pool bonding and scary picture
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    My new equipment pad should be poured today, if it stop pouring from the sky anyway. I intend to get the new controller mounted as well as all the plumbing done in advance as I can with new equipment (main pump, SWG) as well as rough in what will need to connect to extend all the pipes to the pool. On cut-over day I "hope" to schedule someone from a pool company to empty, move, and refill the sand filter and the only remaining plumbing will be the final connections to it as well as cutting what runs to the pool to connect the new stuff. Assuming I can schedule an electrician for the same day to move the electrical circuit (it's along the existing wire path so it should only need to be dug up and shortened) and to extend the bonding.
    I assumed an electrician would handle it, but after what I found today I want to be sure I also know so I can be sure it's correct. First question is once extended the point of connection will eventually end up under a patio slab. Should that be pulled up high enough and mounted on the wall or anything so the actual connection is visible for any future repairs, or safe left under the slab? The second question is "Can you believe this picture????". The wire to the right runs to the pool. From the clamp on back to the left runs to the booster pump. But, what a fine splice to protect my family's safety!!!
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Re: Extending pool bonding and scary picture
    That "splice" is certainly not up to code. There are various ways to fix it, some of which allow it to be encased in concrete and some don't.
    To be able to replace the pump, you really want more slack than that, so that whole section should probably be redone.
    That doesn't really look like copper. Can you tell if it is copper? and just corroded? Nothing but copper is acceptable.
    Mar 2015
    380
    It's copper. Besides being so corroded that splice also allows each wire to move so it's not even tight. The right side heads to the pool. That portion is what I'll need extended by about 12 feet and then the pumps hooked back up there so everything on the left side of that fun looking splice will go away. The area they are currently crammed into will become patio.
    With a licensed electrician I "hope" they can just decide the best means to extend from that point and how, but finding that someone at some point thought this was a good idea had me scared. I have all the installation receipts from the previous owner and it was all done by a local pool company. One receipt specifically for replacing the booster pump and a new Polaris 380. I don't think I'll be calling them to move it.
    Scott
    Apr 2015
    DeBary FL
    8
    That's ridiculous. A $4 split bolt would've handled that bond splice, no problem.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Hartworx View Post
    Exactly what he said!
    You can't just twist wires together. For anything. They have to be held. That's why they make wire nuts, terminal blocks, and split bolts-just like you need here.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mar 2015
    380
    Yeah. A teenager trying to hook up speakers is what crossed my mind when I found it, lol.
    Scott
