Results 1 to 17 of 17
Thread: New Plaster Stains
    Apr 2015
    Cathedral city, Ca.
    9
    New Plaster Stains
    Had my pool replastered 6 months ago. My pool guy evidently didn't follow instructions for new pools, i.e. chemicals, etc. The contractor says its not his fault the whole pool is leaching (even though other people say it is). I am going to have to sue both of them, but what do I do in the meantime. The dumb pool guy just acid washed my new plaster and it got a little lighter but its still leaching something. Can someone help! (hopefully someone that knows of this problem). Is my new plaster ruined now because of the acid was done to it?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New Plaster Stains
    Hi Thomas, and welcome to the forum.
    Sorry to start off with a question, but what do you mean the plaster is leaching? We can probably help answer some questions with this, but the short answer about your plaster being ruined because of acid wash is no, not necessarily at all. Generally speaking, plaster appearance problems are rarely due to startup issues, but rather the quality of the install in the first place. Many builders like to say this is the reason, but it usually has little to do with how a finish looks. Tell us more about the leaching, and whatever else is going on with the new finish.
    Essential Links:
    Welcome to TFP!
    You haven't really described what the problem is, so there isn't any way I can comment on your situation. Please describe more about what you mean by "the whole pool is leaching" and in what way you think the "plaster ruined" might apply? It would also be a huge help if you posted some photos of the problem and a complete set of water test results.
    Apr 2015
    Cathedral city, Ca.
    9
    I say its leaching, because it is completely stained. Greyish color. Can see pool guys wheel marks from his vacuum and its all over the sides of the pool. I don't seem to be able to attach a pic, but your website shows the pictures that look exactly like my pool does, but I cant figure out how to fix or who to blame! Calcium hardness is 130 and Phosphates is 200, Cyanuric Acid is at 0!?
    http://www.troublefreepool.com/threa...plaster-stains
    Apr 2015
    Cathedral city, Ca.
    9
    P.S. By ruining my pool, the plasterer told me that my pool guy should not have acid washed my new plaster, it may have taken a lot away from the longevity?
    Apr 2015
    Cathedral city, Ca.
    9
    Somehow my first response is not posting, so I will reply again. Here is what my pool looks like,
    My ch level is 130 and my Cyanuric Acid is 0!!??
    Acid washing does slightly reduce the lifetime of the plaster, it is also a very standard treatment for scaling, mottling and embedded staining (any of which would fit your description).
    How about PH, TA, FC, CC?
    Apr 2015
    Cathedral city, Ca.
    9
    All other chemicals are within limits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by thomassaccuci View Post
    Do you know what they are? It really is essential for us to help you.
    Essential Links:
    Apr 2015
    Cathedral city, Ca.
    9
    aBBREVIATION RESULT
    FAC 1
    TAC 1
    CH 130 lOW
    CYA O (LOW)
    TA 90
    PH 7.8
    cOPPER O
    iRON 0
    pHOSPHATES 200 (HIGH)
    that's THE WHOLE test done by Leslies Pools
    Apr 2015
    Cathedral city, Ca.
    9
    Re: Why are TFP's recommended levels so different than my equipment manufacturer's?
    Chemists are like doctors, blood test ranges can also vary, but not that much. I am leaning towards blaming my pool guy vs. the contractor, but then I read the contractor could have done all sorts of stuff wrong to cause this problem as well as the pool guy. Need someone to blame and fix.
    I moved this post to this thread as it did not make sense in the thread I found it in. jblizzle
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok,
    There isn't anything in those numbers to indicate a problem that would discolor the plaster. I would like seeing some pictures, and understand what you mean by the "leaching" you mentioned. If that's just the discoloration, it happened during install. Not after the pool was filled, and it's called streaking or mottling. Without knowing more, and assuming those have been pretty typical numbers since filling, I'm not ready to place any blame on the chemistry. At all. Again, most appearance issues are by far caused by the installer/install quality. They often blame the chemistry, and it is hardly, if ever ever the reason.
    Aside from the finish, those numbers are about to lead you into trouble with Algae. I wouldn't be advising you well if I didn't suggest you getting a good test kit, start learning about pool chemistry and addressing those numbers. Your Cya needs to start increasing soon, the FC needs to come up now, and the pH will soon be out of range to the high side. Forget about the phosphate number.
    Start with the ABCs in pool school for a look at the essential basics. The link is above at the top of the forum, as well as the pool school links in my signature.
    Essential Links:
    Apr 2015
    Cathedral city, Ca.
    9
    I hire people to clean my pool, don't need to know much if the guy did his job right. Taking both of them to court since one expert said is was caused by the startup and the other says its the plaster. pics are too hard to see, but I just hired a new guy and he said it had to be from the startup also. so go figure.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Alright then.
    I gave my opinion, and it's based on some expert research done by a long time plaster expert who used to install. As he says, it's rare for it to be a chemical issue. Usually, it's the install. Good luck on your case.
    Essential Links:
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I think you might have trouble mounting a case if you don't learn the rudiments of chemistry here. If you can take the time to acquire a test kit, brush up on pool school a bit, and answer some questions, I suspect there are some knowledgeable posters here who might be able to point you in the right direction. The side benefit, of course, would be that you would be better able to assess and direct your pool service.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Apr 2015
    Cathedral city, Ca.
    9
    I DONT THINK I will have a problem. experts from all over the world differ in opinions about whose fault caused this problem. The plasterer or the pool startup guy not checking the chemicals like the ph and alkalinity levels, not brushing the pool correctly, etc. so, sue em both and they will both blame each other in court like they have been doing for a week, get it. Then the judge can decide himself. I will email you a copy of the judgement when I get it. Probably wont even have to testify as these two idiots will just blame each other and that's it! lol
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Good luck to ya, Thomas. Once the suit is settled, could ya come back and tell us how everything worked out?
    Cheers!!!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
