Thread: Petrol Gel Lubricant?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Ok. I have a question to add to this. Would this work? If not, why?
    It is a petroleum based, food grade, o-ring lube I use for beer kegs.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Re: Lube
    No, you never want to use petroleum based products. Over time they will cause the material the o-rings are made of to break down and fail much earlier than it otherwise would.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Lube
    Quote Originally Posted by JasonLion View Post
    Ok. Just wondering. It is curious that they make such a product for a food service environment, including rubber o-rings. Pretty sure I would rather accidentally ingest silicone or Teflon before that stuff. It is water right, and stays together very well. You have to wipe it off to get it off.
    22,550
    Re: Petrol Gel Lubricant?
    Most pool O-rings are EPDM and most beer keg O-rings are Neoprene.
    Petroleum products should not be used on EPDM material, but petroleum based lubes are recommended for Neoprene.
