Thread: Lube
    Jul 2014
    Crowley,Louisiana
    26
    Lube
    What is the best lube to use? Teflon or silicone base? Currently just using a water base for installing, but I think its probably only good for installing and not for the life of the o-ring.
    16x48 Intex above groud 6500 Gal. w/Krystal Clear (Intex) 16" sand filter & SWG system (2650 GPH). Two different homemade sprinklers, will post pics when I learn to use the forum better.
    Re: Lube
    Any silicone or teflon based plumbers lube is fine.
