Results 1 to 9 of 9
Thread: New Pool in South East Florida
    Apr 2015
    South East / Florida
    6
    Hello fellow pool owners:
    I am in the process of building a pool
    Pool Size: 15' x 32' with cut corners (90 lft)
    Spa Size : 7' Hexagon
    Permits are all squared away.
    I got to change the plans due to the pervious/impervious ratio.
    Deck (red marking on picture) is going to be bishop hat.
    Will post more during the process and will appreciate any feedback.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Re: New Pool in South East Florida
    Im curious so I will ask a question.
    Is there any particular reason you put the skimmer in the corner?
    If that the direction the usual prevailing winds will push debris?
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    We don't normally recommend cutting corners around here. But, in your case we can make an exception since it looks good so far!
    Apr 2015
    6
    It was recommended by the builder. Not a personal choice. Do you think the skimmer should be placed someplace other than the corner?
    Pool 16,841 GAL, IG, Marbletite plaster, Hayward Aquarite T-15, Filter C-2002 Hayward Cartridge, 2 Hp, 2 speed variable Hayward Tristar Pump, No Heater, Automation Hayward Aquaplus + Aquapod, Spa= 7' Octagon 700 GAL, Raised 12" Deck Pavers: Bishop Hat , Pool build started 3/30/2015
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I think skimmers work well in a cut corner. Too close to a regular 90 corner can cause issues due to poor flow. As long as it is down wind of prevailing wind flow, you should get great results.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Apr 2015
    6
    Thanks. Dig is completed.
    Apr 2015
    6
    The framing is now completed. I will try to setup pictures thru photobucket to save bandwith.
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    I always forget how sandy your soil is, so vastly differently from our rock hard/clay soil here.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    Casey's Avatar
    SW PA
    10,457
    Lookin good! Keep the pics coming!
