Thread: pump timer opinion?
    rajung's Avatar
    Mar 2015
    Iowa
    188
    pump timer opinion?
    my pump has a 20amp, 15ft long cord with a large GFI attached near the plug end,this plugs directly into another GFI on my outdoor service post.
    This year I would like to get away from running my pump 24/7 unless I run my heater which will shut down" lock-up" if it notices no water flow.
    I purchased a mechanical outdoor metal timer,encased it into a plastic weather proof large box housing for extra measure,drilled 2 holes on bottom with weather proof cord cable restraints,wired male connector to timer which will plug into service power post 20amp GFI.
    Then also wired female plug to timer which I intended to plug the original power cord from pump into that.Problem I have, I noticed when ever I unplug the cord from the outlet, the factory in line GFI trips and I have to push re set button.So my timer idea I thought would be great,is not going to make anything any easier as I would have to continually re set the breaker after the time shuts off the pump and re starts a few hours later.
    I like the in line breaker on the Doughboy pump and don't know if I should eliminate it and just count on my GFI of the receptical alone?
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: pump timer opinion?
    Sometimes two GFIs in a row can give each other trouble. It is certainly safe to eliminate one of them. We had our Intex salt and pump GFI plugs plugged into an outdoor timer and into a nonGFI outlet and it worked great for several years.
