Results 1 to 10 of 10
Thread: Pump motor still trips breaker after replacing capacitor
    May 2012
    Houston, TX
    37
    Hello all.
    About 10 days ago, I noticed that my pump wasn't running. The breaker was tripped, and when I reset it, the motor hummed and then tripped the breaker again. I looked around on the internet (including here) and figured the capacitor was bad. I was able to turn the shaft by hand. Motor is 2hp made by US Motors, installed 3 years ago. I replaced the shaft seal a couple of months ago because I noticed I had a leak.
    Ordered a new capacitor, same ratings as the old one (50 uF, 370VAC). installed it today, and the pump ran for a few hours and I though my problem was solved. I happened to be outside, and noticed that the motor was sounding different. It was making a somewhat high-pitched sound besides its usual sound. Then the breaker tripped again. Tried resetting the breaker, but the motor just hummed loudly then tripped the breaker again.
    Could the replacement capacitor be a lemon? Anything else I could try before calling someone to make the necessary repairs for me? I was hoping to be able to do it myself, but may be in over my head.
    Thanks in advance!
    ___________________________________________________
    Apr 2015
    Pennsylvania
    8
    Re: Pump motor still trips breaker after replacing capacitor
    Do you have an amp probe? Or know someone who does? If you get one: Start pump and run it, put amp probe on black wire on incoming power line, assuming its a 120 volt motor; 220 volts it does not matter which wire (wherever you can access it). Read the amount of amps being drawn. Now, look on the motor nomenclature look specifically for a RLA number this means Run Load Amps. Compare your actual amps to RLA if you are exceeding then there is another issue going on. For example RLA rating 10 actual 9.5 that would be normal. IF you where reading say a 12 amps then it means the motor is overloaded and could possibly trip a breaker. If its is overloading then *could* be a capacitor, pump failure (bearing) causing excessive load, has anything changed in the plumbing? Pushing the pump beyond its capabilities? Also I would check all connections from the breaker panel to the pump motor a loose connection would cause hard starting and will trip a breaker once things start heating up. Start with these items and we will go from there, there is more you can try but start here.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    The motor numbers to ID it would be helpful.
    Is there a chance it has both a start and run capacitor ??
    Solar Blanket, Well Water, Borax Added. 68
    Oct 2007
    Parkland, FL
    752
    High pitched whine is probably the bearings. Just buy a new motor and seal and install it. It really isn't that hard, I've done it at least 4 times already.
    Quote Originally Posted by caliking View Post
    Hello all.
    Thanks in advance!
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    OR . . . IF the bearings are a problem, rebuild it yourself.
    https://www.youtube.com/watch?v=CcrHwAL7V7w
    May 2012
    Houston, TX
    37
    I posted a pic with the motor details. I think it is the bearings, because of the high pitched screeching just before it started tripping the breaker again. Also, the motor had been sounding much louder prior to stopping the first time. The motor did run for a few hours when I replaced the big capacitor at the end of the motor.
    Quote Originally Posted by Pool Noob View Post
    I don't have an amp probe. I think the bearings are bad, based on what others have described elsewhere on the forum and the responses here. Could worn out bearings cause the capacitor to malfunction? The original capacitor and now the replacement capacitor are not bulging out or looking shorted out or anything.
    May 2012
    Houston, TX
    37
    If I replace the motor, any ideas on which one to buy and from where? The current motor replaced an AO Smith one, which I think most likely just had a bad capacitor, but I had not found this forum back then.
    I think I still have that motor somewhere, so one thought would be to get a new capacitor and install that instead. It was in use for about 9 years I think. I'm starting to think that my current motor is not a very good one. Purchased from leslie's, installed it myself, but in less than 3 years, the shaft seal went bad, and now looks like the bearings are shot.
    If I opt to change the bearings out, how do I know what size bearings I need? Best place to purchase?
    Oct 2007
    Parkland, FL
    752
    I don't think bearings are all that easy to change. New motor is around 245 bucks it looks like from electric motor warehouse, they usually have the best prices.
    May 2012
    Houston, TX
    37
    Quote Originally Posted by robl45 View Post
    I may end up buying a new motor. Changing the bearings looks like something I could accomplish, but time is at a real premium at the moment with a 1yo at home and recently starting a new job. Thanks for the info.
    May 2012
    Houston, TX
    37
    As follow-up to my issue, I ended up replacing the motor with a Century/AO Smith 2HP motor. $280 on Amazon. Installed it 3 days ago, and things seem to be running smoothly. The new motor is MUCH quieter than the old one. Thanks everyone for the helpful advice.
