Thread: Water shoots out of return like a geyser
    Apr 2015
    Rocky Mount, NC
    1
    Hello, I am new to this forum and I have been researching on how to hook up a sand filter to an Intex above ground pool. The pool my family owns is small, about 15'-16'. We recently bought a Hayward sand filter, 16" filter tank with a 1.5 hp pump. Originally, amazon said it was a 1 hp pump but on the pump it's labelled 1.5. I'm afraid it might be too powerful? When I hooked it up to the pool, first I tried with the hoses that were supplied with the pool originally, water was shooting out like a geyser out of the return. Is there any way I can reduce the water pressure? would hard plumbing it with valves to control water flow into the pump work? Any advice would be helpful!
    Sabrina
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Water shoots out of return like a geyser
    Welcome to TFP Sabrina
    It could, but the pump still might push things through your sand filter and that is the real problem here. You simply may have too much pump.
    Essential Links:
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum SabrinaRinaBoBina
    Can you please add your pools info to your signature as outlined here (best you can): http://www.troublefreepool.com/conte...etting-started
    Can you also post the part and or model numbers off the filter, pump and motor so we can look them up ??
    Any chance you have photos of how it's set up ??
    Solar Blanket, Well Water, Borax Added. 68
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    You don't want a valve to cut down water flow into a pump, it needs to be on the output side to reduce outflow. Restricting flow into a pump can cause pump damage.
    Texasrebel's Avatar
    Mar 2015
    Conroe/houston
    28
    As a licensed plumber I would say way to much pump...you probably only need a 1/2 hp and at max 3/4 hp
    IG gunite/plaster 9,200 gals-with 7x7x1-1/2 splash pad with bubblers.
    3/4 hp hayward super pump for bubbler and water fall-1 hp hayward super pump for filtration
    24" hayward sand filter.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Yep. Too much pump. I have a 1.5 hp pump on a 34K gallon inground pool. Can you return the pump? I know Amazon has always been good to me about returns. You could put a valve on the outlet of the pump before the filter to slow the flow, but my biggest concern would be the extra electricity you are burning with an oversized pump. Of course, you shouldn't have to run it too long each day, so the actual $ amount is probably negligible.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
