Results 1 to 7 of 7
Thread: Readings
    Apr 2015
    South Louisiana
    2
    Readings
    Have had goldline aquarite installed for several years with no major difficulties. Starting up this season I have the following readings on my panel in this order
    0
    79
    0.0
    0.00
    71p
    -0
    AL-0
    ~1.40
    0
    Can anyone tell me what my problem may be?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Readings
    The readings show no salt (measured by the cell) and so no power to the cell so it could be a failed cell.
    How old is the cell?
    Are any other LED's lit?
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    38,284
    Re: Readings
    Welcome to TFP!!!
    According to that you have it set for 71% output ... that means it is only generating 71% of the time. Maybe you looked at it when it was not.
    Although I thought it would still show a salt reading even when it was not generating.
    Have you checked the manual? They are available on the Hayward website.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Readings
    You can also try selecting super chlorinate and see if any of the readings (volts, amps) change but I doubt they will since it's not measuring any salt.
    Apr 2015
    South Louisiana
    2
    Re: Readings
    No other light lit. I have two cells and I keep one clean to rotate. Both give me the same readings. We have had our share of rain as always but I added two sacks of salt and still no reading. Changed out the nickle sized diode but still nothing. Does anyone rebuild boards or sell rebuilt?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Readings
    Hmm, my next guess (just a guess) would be the current limiter because it's a part that fails frequently. How does it physically look? See if the video below describes your problem.
    https://www.youtube.com/watch?v=TOJ6WcW9CYs
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Readings
    Welcome to the forum wpbroussard
    Solar Blanket, Well Water, Borax Added. 68
