Results 1 to 7 of 7
Thread: Automatic Chlorinator?
    Jun 2012
    NW CT
    77
    I'm not sure if this is the right forum to post this but I'm sure someone will move it if needed.
    Anyway I have to find a solution to my problem before I can open my pool this season. Due to some life changing events I need to figure out how to add bleach to my pool automatically. For work I travel and can be gone for as much as 3 weeks at a time. I no longer have anyone at home to test and add bleach daily. Thats my problem.
    I've use the BBB method here since we did the install and don't want to change. I've used bleach only and trying to remember what we added on average daily. I'm thinking it was between 4- 8 cups a day to maintain. So can anyone give me some suggestions on what I can install to do this for up to 3 weeks? Again I don't think I want to go to anytime of pucks just because from what I know about that they tend to add a bunch of stuff I don't really want to be messing with. My pool stays really good without having to add much other than the bleach.
    Thanks for any suggestions
    43x21x54" Sharkline/Wilbar Above Ground with hopper, 26,000 Gal
    Sta-rite 22 in sand filter with Zeosand removed reg pool sand installed, Sta-rite 1.5 hp pump, Poolsmart Climber Robot, TF-100 Test kit, poolskim, hard plumbing with second return added for poolskim, fafco solar heater, Luiquidator
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Automatic Chlorinator?
    How about converting to saltwater? That will eliminate adding bleach entirely.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    SWG, liquidator, stenner pump are 3 choices. Mine would be a SWG.
    Jun 2012
    NW CT
    77
    I just ordered the Liquidator. I think it was the cheapest route to go for me at the moment. Also I'm hesitant to change over to saltwater 1. Because with a new job and being gone so much now I don't really have the time to figure out a new system. 2. Because I'm hesitant to run salt water with my AGP. I'm concerned with corrosion it may cause. I have seen people do it on here. I hope this works for now to solve my current issue. Thanks for the recommendation.
    Orlando, FL
    690
    I love my liquidator and I've had it for about a month. Easy to install. I believe the 8 gal system will give you closer to three weeks. You hopefully will be able to babysit it for a week or so because it takes some tweaking. Many posts about setup and useful tips on thid forum.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    38,470
    A 26k pool is on the large side for a Liquidator just due to the amount of bleach that must be added daily. You will need between 2/3 of a gallon and a full gallon of 8.25% daily to add 2-3ppm so you may find yourself having to fill it weekly.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    A 26k pool is on the large side for a Liquidator just due to the amount of bleach that must be added daily. You will need about 2/3 of a gallon of 8.25% daily so you may find yourself having to fill it weekly.
    Agree -
    The capacity limitation of the Liquidator was one of the reasons I went with a Stenner pump. My tank will last just about a month without refilling.
    Support the site
